I realise that the correct answer is "get a Mac" but while I may have the opportunity to get a new laptop in the near future, I won't be getting that wealthy.
I currently have a fairly low spec laptop running Windows 10 and the latency on Reaper is just too poor to be able to record and monitor via my very basic Behringer interface. What should I be looking for in terms of hardware to allow me to run Reaper and so on effectively?
I don't need any particular performance from the laptop in terms of video, gaming or anything like that, it will be used for occasional zoom calls, Internet browsing and remote access of my work PC on the odd occasion I need to work from home.
I just want to be able to run my guitar into my interface, record a clean track in Reaper, and then have a second track to monitor and run VSTs etc.
Pretty much any modern computer can do what you are asking.
You often find s/h machines here that would do the job easily.
That's generally why people have problems, they have too much background tasks running and that interferes with the audio, causing pops and clicks. Unfortunately they are loaded like that by the manufacturer so it takes a bit of work to strip all the crap out of the startup.
You tend to get better performance per pound out of AMD chips rather than Intel. AMD Ryzen 7 CPU with 16MB RAM will be good and will run anything you throw at it. Get a reasonably sized internal drive, say 500MD SSD and a big external hard drive (at least2 TB). Make sure your USB sockets are USB 3.0 and your external drive will run fast. Install your programs on your SSD drive and your libraries on your external. Sorted.
as Danny said, clear out all the unnecessary stuff and a spec like this will last you a long time.
have a look on Scan and PC Specialist, you can gauge the price of stuff quickly on there. Both good sites and reliable providers.
And no "get Mac" is not the correct answer! It's just a preference. Modern Macs and PCs are equally as good as each other in terms of making music.
That may or may not be a buzzkill depending on your workflow, skill level and personality.
Macs are not 'zero maintenance' they just require less, as a rule.
[dons flame suit]
I got my desktop (with an i7 processor) from Scan a few years ago, which was from their list of Pro Audio systems and it's been excellent. I see they've got Laptop options as well.
However, my laptop is just a HP model from John Lewis with an i7 processor and (although not as capable) it's OK. It's only got 8GB of RAM as well, but I won't be running any big music libraries with that.
Personally, to err on the safe side, I think I'd go for at least an i7 processor, the AMD equivalent or above. But it appears from the posts above that others have got away with lower spec. options.
For a low spec machine, one potential solution is to use a Line 6 Toneport (I think they're called Pod Studio now) and monitor with the built in sounds when recording. I used one of those (a GX) with a super low spec netbook. I suppose one of the Helix family would be an upgrade to the Toneport.
soundcloud.com/thecolourbox-1
Interface: Native Instruments KA2, Focusrite Scarlett, Steinberg UR22.
Cake: I'm favouring lemon drizzle right now.
PC Specialist is very short of stock at the minute. The only laptops with AMD in at the minute offering the R9 5900HX. Glad I ordered my R7 laptop at the start of the year anticipating greater shortages this year.
I don't have my current laptop, my wife is using it until she gets a new one, but it does have a Ryzen processor. I'll check the specs later and post them, could someone let me know if it could be bullied into working? My IT skills are limited but I can generally follow instructions!
Current W10 build is very good when it comes to latency.
I have decade old computers working fine with Reaper.
Both run Studio 1 v5 Pro with no issues at all.
Any difference between them is in post production like rendering finished files.
Any current windows machine, if set up right, will do the job just fine.
Just because you're paranoid, don't mean they're not after youRyzen 3 3200 2.6GHz processor, 8GB RAM. This should be OK? But get a better interface - any recommendations on the cheapest that will do the job - 2 channel will do.
It should use ASIO but (at least in my case) I see the name of the interface mixed in with the word ASIO, I'm not sure if that's always the case. There's a drop down list in Reaper Preferences>Audio>Device. Do any mention ASIO along with the name of your interface?
On the face of it your laptop CPU spec isn't massively different to mine.
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-7500U-vs-AMD-Ryzen-3-3200U/m171274vsm771805
Just double checking: When you say the latency isn't low enough, what is the exact nature of the problem. Have you tried lowing the buffer size to see what you can get before the onset of pops and clicks?
That means a minimum of 3200MHz RAM, if not 3600MHz.
Intel CPUs don't really suffer from this problem, but equally...they're not as fast (generally).
Drew and I did some testing on it a year or so ago. Basically, I upgraded from an i7-6700 to a Zen2 Ryzen 7 (a vastly superior CPU), and I could no longer record at 96kHz/24-bit with acceptable latency without pops and clicks. I ended up having to replace all of my RAM in order to get there.
I've always used PC, right from 1992. It's what I know and understand. I have a Mac Mini as well, which is running a mac os prototype of Cakewalk/Sonar. I don't really like the Mac OS, but that's probably down to familiarity more than anything else. What I do like about Macs is that they truly are turn on, plug and play with very little fannying about.
However, Windows 10 has addressed a lot of that and for me it runs very well. Also, I've found that PC reliability has been transformed in recent years.
If you want a laptop that will last forever and be fantastic to work with, get a Dell XPS. It will cost a bit, but they are superb. I've had one running for 4.5 years now and its like new.
The driver is ASIO4ALL, yes, it's not a specific one to my interface, or to Behringer or any other manufacturer. On the drop down in Reaper, it doesn't mention the interface on any of the options.
I can monitor the input from my amp via the direct monitoring on the interface, but this means I need to play a completely clean signal, which I can then add effects to later in Reaper, or use my amp's drive channel/pedals etc, and not have a clean signal I can then mess around with. Ideally I'd like to be able to record clean on one Reaper channel, and then monitor with effects on a second channel.
The issue with the latency is that there is a good half second of delay between picking a note and hearing the note. If I adjust the latency down, I get a lot of pops and clicks long before the delay goes, and if I adjust down further I get a fast repeated sound and the screen starts to "flash."
I have no idea of the speed of my RAM, I presume I can look that up in the system information?
My RAM is 2400mhz, can this be upgraded by simply swapping for faster RAM, or is it not that simple?
