Mike Hill Services Board in very large flightcasse - Spares or repair - £10 pick up only
As an edit to the post, this is now available for collection if anyone wants it, £10 only!
The actual board and flightcase are perfectly serviceable, in fact a lick of paint and the board would be good as new really.
I'm in Leicestershire if that helps folk decide on whether to make the journey, I also travel south for work so could meet somewhere.
More gallery pics here:
https://imgur.com/a/CQxxCQdI was looking for some information and assistance with a pedal board setup that I picked up recently cheap off ebay. It's a Mike Hill services build, and the chap I bought this from had this made around 2000-2001. Unfortunately, when he was no longer able to ship it around, he stored it in his cellar and it's been there for around 10 years, as a result it's suffered from damp egress and is looking a little worse for wear. He sold it honestly enough, and I was happy to take a chance and see what horrors might lay in wait!
I've attached some pictures of the board and the inside of the power/signal chain box so I can hopefully find out what the original setup was, and also what needs replacing (all of it!!). I'm guessing it's pretty much all useless, but hey ho, if you don't ask you don't know!
I can see the input marked 7 appears to be the original input perhaps, theres also an fx loop insert and finally what I believe is a buffered loop perhaps, marked 8? Theres also an unconnected and cut midi cable which I believe was for the sellers amp channel switching. All of the PCB's show signs of corrosion on the back.
With the power transformers I can see a 12v, 9v and 18v I think, along with filtered outputs perhaps, however the PCB's again are corroded as are the transformers. I've not powered it up as I think it will go bang.
My head said brake, but my heart cried never.
Does the input with the circuit boards seem to you like a buffered setup?
Thanks mate.
Can't absolutely guarantee it won't go bang, but if it does it's more likely to be one of the voltage regulators or filter caps.
Yes, most likely.
The flight case alone is probably worth that!!
