Celestion g12s 20 watt speaker , any good ??
riffpowersriffpowers Frets: 344
I’ve been given a knackered amp with a 70’s celestion g12s 20 watt speaker in it .
I was just wondering if it was worth removing and maybe using in a 2x12 for my studio 20 head ??
Anyone know much about em ? Anyone like em ??
  • ICBMICBM Frets: 72331
    Yes, they're extremely under-rated speakers, and I don't just mean the power rating . They used to be thought of as a bit weedy, but that's because they're not very efficient - about 95dB I think - noticeably quieter than the usual Greenback, G12H-30 etc. The actual tone is very nice - they don't have a huge amount of deep bottom-end, but the voicing is not too far away from a Blue. A pair of them sounds great in an AC30, and means you can drive it hard without blowing the windows out.
    It would sound really nice in a 2x12" with another deeper-sounding speaker and a Marshall, I think - it will have more of an old-school classic/blues-rock kind of sound than the standard SC 2x12" cabinet which comes with V-Types. Just be careful with the power rating - it will be fine paired with another speaker, but I wouldn't run the SC through it on its own, they don't seem quite as conservatively-rated as some Celestions (another reason they might not be very popular).
  • I was just thinking of using it for playing in the house , so the low dB might actually be useful for that.
    Exactly. They’re also a speaker which doesn’t need to be pushed hard to sound good, they sound nice down to a whisper.
    In the old days inefficient speakers were thought to be poor because they weren’t loud and punchy for gigs, but we’re in a different world now and it can be a positive advantage to be able to turn the amp up a bit further but keep the volume down.
  • This was interesting for me because it appears I've got two of these in a carlsboro scorpion combo. Having read @ICBM 's comments above I'm now considering trying one in my AC15.
    edited October 2021
    I would definitely do that. Check the impedance first, I think they will be a pair of 16-ohm ones in parallel in the Carlsbro (although I could be wrong). If you can hook up a temporary cable to one of them you could try it in situ without having to take the Vox apart. Make sure you disconnect it fully from the Carlsbro amp section.
  • I’ve been given a knackered amp with a 70’s celestion g12s 20 watt speaker in it .
    Good speakers, ideal for bedroom players in my opinion. Exactly the same as a G12M just with 7oz less weight in the magnet. Bit quieter with less bass, but all the tone is there.
    Yes they are 16ohm. I will give it a try!
  • I use an old T1417 20watter pulsonic cone, single speaker with a 100w head and an attenuator, it's all a question of balance but the reward is, you get speaker distortion in the mix with amp distortion/drive. It's more an alive sound imo but well worth a try if you can.
    Always worth checking some of those old speakers first as a lot have cone issues but if you get a good one the warmth will reward.
  • Just reporting back that I've now done this speaker swap. I'm very impressed with the sound so far, considering I didn't hate the Wharfedale that was in there. The Celestion G12s I would say has a more clarity and is less prone to sounding harsh when turned up loud. It's more of a difference than I was expecting, and a definite improvement.
    So, thanks @ICBM for the idea, and @riffpowers for bringing it up in the first place!
  • That bodes well for when I do it !!
  • Will be interested to hear what you think @riffpowers. Do let us know.
    It’ll be a while cos I need a donor 1x12, but I’ll post back with results !!
  • I'm just resurrecting this thread as I picked up a pair of these on ebay a while back. Assuming they actually work, how silly would it be to run these in a 2x12 with an Orange Rocker 30 head? Am I sailing a bit close to the wind wattage wise? I don't imagine I'll ever have the need to crank the Rocker 30 much past 12 o'clock but I also don't want to be playing and worrying at the same time - it doesn't make for good music!
    Blackbird Cabs - bespoke guitar cabinets, handcrafted in North Devon
    sam@blackbirdcabs.com
    It should be completely fine - you can put a pair of them in a fully overdriven AC30 without any problems. As Bygone_Tones said above, the cone/voice coil is the same as a G12M-25, so the 20W rating is probably on the conservative side even for Celestion.
  • Thanks @ICBM, that's exactly what I wanted to hear. I'll post my thoughts on the speakers once I've had a chance to solder etc (probably once the kids are back at school).
  • RickLucasRickLucas Frets: 401
    I had an old Carlsbro PA cabinet with 2 of these speakers. I played a JTM45 through it and it sounded lovely.
  • daddyashdaddyash Frets: 40
    My WEM dominator mk3 had this speaker in.
    Sounded great. Not just at low volumes but cranked it sounded amazing with that amp.
    Wish I’d not sold it now!!
