Fitting neutrik plugs to fender tweed cable
I seem to have an excess of broken fender tweed cable. There doesn't seem to be much point in re-soldering the plugs as they're the weak point.  Is it worth salvaging the cable and fitting neutrik plugs? Are there any compatability issues?
'Vot eva happened to the Transylvanian Tvist?'
  • Danny1969Danny1969 Frets: 10455
    The fault with the Fender plugs .... at least all the ones I have seen is they pull tight the hot conductor and then solder it. This means a slight yank on the cable will bend the strain relief and break the connection.
    You're supposed to solder these jacks with a little bend in the hot conductor to allow for movement. You can use Neutriks but it's quite tight. I tend to drill out Reans or sometimes use Amphenol jacks instead.
  • mrkbmrkb Frets: 6920
    edited October 2021
    I’ve fitted neutriks to my black woven fender ones- it is tight, had to cut a lot of the end wall of the screw on cap away. But working fine.
    you’ll also need a lighter to melt the braid back together if you cut it.
    Karma......
    Ebay mark7777_1
  • What's the diameter of the Fender cable?  Neutrik also do a plug to suit fatter cable: https://www.neutrik.com/en/neutrik/products/plugs-jacks/plugs/professional-1-4-plugs/jumboplug
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • ICBMICBM Frets: 72642
    Aha… those look great. I didn’t know about them - I’ve been using the older NP2Cs, which you can still get.
    Oddly, the right-angle NP2RXs can be got on, but the straight NP2Xs are almost impossible.
    (It’s about 8mm I think, to actually answer the question!)
  • Yep, 8mm.  Sorry, a little late to my own thread.  Cheers for the replies as always.
