It usually doesn't matter unless you have the channels set very close to the same volume though - you'll hear when is too close if you listen for the drop in volume.
(Incidentally this also means you need to be careful with valve choice for V1 - Russian-made 12AX7s don't like being used as cathode-followers.)
Quite an interesting effect, jumping the channels...not sure if I'll use it for anything, but good to experiment.
Thanks for the advice!
