Very basic AMP repair and mod help
So I've bought (very cheaply) an Orange Crush 15r, the power switch is stuck (in the off position) so thats a relatively easy fix. Its also got a hardwired power cable which I'm not a fan off. So i plan to fit a panel mount IEC socket like this https://uk.rs-online.com/web/p/iec-connectors/0488191 ( to save clicking, that one is 10a 250v, panel mount with 2 screws)
  I've built pedals, done some rudimentary home wiring so i'm fairly confident but I was always told to ask someone who may know better before doing anything you are even 1% uncertain about. So to allay any nagging doubts I may have, are there any pitfalls to my plan?
  I did think of fitting a jack output to run the amp to my cab but I'll prob not do that (unless I find a switched socket on RS somewhere)
ta in advance
  • ICBMICBM Frets: 74472
    All the photos I can find of a Crush 15R show an IEC socket, not a hardwired mains cable. Has it already been bodged?
    A switched speaker jack is a very easy mod, just make sure you use a plastic-bodied jack so it doesn't short to the chassis.
  • spev11spev11 Frets: 474
    doesnt look bodged, there's no hole for a previous IEC socket anywhere on the amp, all the orange amps that have an IEC its usually on the white metal near the switch, this cable is coming out of the corner of the cabinet, bottom right. I'll take some photos tomorrow
    Ah, OK - I finally found one. It looks like a very old version.
    There’s no reason you can’t fit an IEC socket. I would be inclined to go through the wood rather than the metal back panel - much easier to cut. If you make a neat tight job of the hole and screw it firmly to the wood it will be safe. You should in theory have it PAT tested, but if you know what you’re doing there’s no real risk.
    You could also fit a speaker jack through the wood but you’ll need to cut a bigger hole and put a jack plate over it, the panel will be too thick for it without one. If you can drill the metal it’s probably easier.
  • FlipFlip Frets: 68
    ICBM's comment is to the point. The only way I know to correctly and neatly fit sockets is to buy a hole cutter and they're very expensive unless you're doing a lot.
    I fitted the mains socket using a dremel type cutter and just took my time, look and works fine( got the shop PAT tester to check it out as well) , didnt bother with the jack out as I decided its my work practice amp for now.
    Excellent! Well done :).
