Black Mountain plectrum, thumb pick thingies?
  • stevebsteveb Frets: 42
    I have some. I started to learn some thumbstyle playing in 2021, i like them for that but couldnt get used to using then instead of a traditional plectrum, just because of the way i hold a plectrum. I bought the tighter ones.
  • I got one just to try out, but not for thumb-picking. It's to use like a 'normal' plectrum during a couple of songs in our set where we have to clap at various points in the song, and I had a tendency to throw picks all over the stage when using a normal pick!
    It works OK as a normal pick, but I always swap back to my usual Dunlop Tortex for the rest of the set.
  • BillDLBillDL Frets: 7285
    I like to swivel my pick around while playing so that I can use the blunt corners for some playing and switch back to the sharp tip for other parts.  For that reason I found that that particular design combination of thumbpick/flatpick didn't work for me.  If I need to use a thumbpick I use a standard one that I have filed back from a long thin pick to a stubby one that just catches the strings and no more.
  • I have one but find the 1mm too thick. I do believe they are planning a medium thickness model soon though.
  • JCA2550JCA2550 Frets: 439
    Have you managed to get to grips with the technique?
    No,I dont like 'sharp' picks in general. I prefer the more rounded style and there dont seem to be any thumb picks like this. When I first started getting lessons I showed up at a lesson with a thumb pick and my guitar teacher advised me to just use it like a traditional pick. I understood this but it still didn't help much at all.
  • StuckfastStuckfast Frets: 2417
    I use the Fred Kelly Bumblebee thumbpicks which are a similar idea and available in several thicknesses. They're basically like a conventional plectrum attached to plastic loop that goes round the thumb. Best thumbpicks I've ever tried but I still find them a bit awkward to use as a plectrum for lead playing. I wonder if this works any better.
  • Jimbro66Jimbro66 Frets: 2430
    No,I dont like 'sharp' picks in general. I prefer the more rounded style and there dont seem to be any thumb picks like this…………
    The Fred Kelly Slick Picks have a more rounded end and are nice to use. Bear in mind that many thumb picks are supplied over-length and need to be trimmed back which can include rounding them off if preferred.
    When I needed a thumb/flat pick hybrid for hot country playing I used Herco flat thumbpicks. I still often use them now.
    The Bumblebee thumb picks mentioned by @Stuckfast have the advantage of being able to swivel the pick a little to strike the strings at a better angle and get cleaner tone. There are also Zookies which are sold with three different tip angles for a similar reason.
    @JCA2550 you don’t mention what sort of music you want to play with a thumb pick and whether it is on electric or acoustic guitar, or both. It does have a bearing on the choice.
    Nothing specific in mind, I tried using thumb picks yonks ago and basically gave up on them. Was curious about these. Oli Brown uses some kind of pick attached to a thumb pick which I think are Fred Kelly ones.
    Herco are ok. I have both a medium and a heavy.
  • bertiebertie Frets: 13569
    looks like a jack of no trade  to me
  • Is the Fred Kelly Derin thumb picks any good?  Also looking for finger/thumb picks.
    “Ken sent me.”
  • I would also say that thumb picks,in my limited experience,seem to work better with heavier gauge strings?
  • GandalphGandalph Frets: 1589
    I’ve got a couple of these, I also use the Fred Kelly Derwin speed picks and the Dunlop brown one’s. The black mountains are pretty good, the spring has held tight but I don’t think they give quite the same ‘thud’ to the strings for blues as the dunlop or speed picks.
