Amp blowing? Amp problem
  • thebreezethebreeze Frets: 2803
    ICBM said:
    thebreeze said:
    Sorry @ICBM quite right, we just crossed - there's more detail above but say if you need more.
    OK, so it is valve rectified - the 5AR4/GZ34, which will usually be at the end nearest the power cable/socket. There is a reasonable chance that this valve has failed, and the burning smell was coming from the base of the valve, rather than the socket. A short in the rectifier can blow the fuse even before the valves have warmed up.
    What to do is remove the rectifier valve, replace the fuse - you should be able to get the correct value on Ebay if you don't have one, you only need a couple - and power up again. If the fuse blows again with no rectifier in, it's a definite tech job.
    If it doesn't, it's probably worth buying a new rectifier valve (spares are useful anyway, and these aren't too expensive) and try again - make sure the amp is on standby when you power up. If it now blows immediately it's still a tech job. If it works until you switch from standby to on, it needs further investigation - there's probably enough to be going on with here!
    Okay, brief update (@bertie). ; I removed the GZ34 and replaced the fuse with a new one.  Blew immediately with a bit more of a bang this time and there were traces of smoke too.  I'll take it to a tech at some stage and let you know the upshot.  It's a shame as its the most amazing sounding amp and always behaved impeccably.  No idea why it's so suddenly being really weird?
  • bertiebertie Frets: 13569
    thanks @thebreeze ; -   doesnt sound so good,  but good luck !!
    Cheers man, its a bummer for sure.
  • ICBMICBM Frets: 72364
    Unfortunately that's potentially really quite serious. If you're lucky it might be the rectifier valve base - they can sometimes arc and carbonise, although in an amp like this I would probably expect it to be a ceramic one, which are almost immune to that - but if you're unlucky it could be the power transformer.
    Sometimes things just fail. They shouldn't, but they do...
    Thank you for all your help.  Yes, it's getting on a bit I suppose.  The answer is don't stop using your amp!!
