I've got a couple of old WEM 2 x EL84 heads which are fantastic little amps. I'd like to be able to use them together into a 2 x 12 cab loaded with Celestion Blues, one amp into each speaker.
The Woden output transformers in them are marked with a 15 ohm and 3.5 ohm "taps". Problem is the Blues I have are the 8 ohm version. There are other unused "taps" on the output side of the transformers, but these are not marked ... are they likely to be 8 ohm? and could someone tutor me as to how I'd work it out with a meter?
Hopefully someone familiar with the amps or transformers will pitch in?
Meanwhile, you say "other taps", plural? I would expect only one more. Normally you have common, 4, 8 and 16. Check with a meter to see if these taps are 1) continuous and 2) connected to the other, known taps.
You MIGHT be able to work it all out by resistance but generally secondaries are so low that it is hard to tell them apart.
Best way is a 15R load and a constant signal and read the volts. We can go into that more deeply if need be.
Push comes to it, run 8 Ohms on 15 tap, no biggie!
Dave.
Many thanks chaps. I'll have a look tonight and report back. Interestingly the schematic for the amp only shows a 15 tap but not a 3.5. though this schematic is a couple years younger than the amps, it seems correct in every other way.
As a matter of interest what is the function of the 0.002uF caps and 4.7k resistors around the output tube side of transformer?
Oooo! Did not think about 100volt taps and me having done quite lot of work on 100V line PA systems.
BTW, anyone know why the Yanks use 70.7 volts? Seems a bit pointless and just makes the sums harder!
Dave.
The caps and resistors on the primaries of the OT are Zobel filters, which flatten the impedance curve of the OT and speaker and makes it easier for the valves to produce a wider bandwidth (closer to a resistive load). You often see it in hi-fi, PA and sometimes bass amps, including solid-state ones, but rarely in guitar amps.
Thanks @ICBM I think these were originally meant to be bass amps but perhaps PA also? Makes sense then. So are the Zobel networks not used in Guitar because they have a bad / limiting effect? or is it they are just perceived as not needed and therefore reduce the component count? Whichever, I really like these amps for guitar, really harmonically rich clean and vintage small Marshall when driven.
I saw those CR networks (called "snubbers" when used in SMPSUs and line timebases) across the really cheap transformers in telly sound outputs.
IRRC they were there to cut 3rd harmonic distortion which might actually be the case since the speakers were almost always also small and cheap and therefore tended to have a good but spiky HF response?
Dave.
Yeah, meant to say "guitar amp peeps" probably like the distortion and the speaker would filter out the worst of it.
As for cost, tellies were as cheaply made as possibly (who remembers Radio Rentals?) and a cap and an R was cheaper than a decent OP traff!
Dave.
I no longer have the book but I recall a Mullard transistor audio circuits collection gave the operation of the Zobel network as cancelling out (to a degree) the inductive component of the speaker which could (they said) lead to transistor breakdown.
I shall give Amazon a go now I am reminded of the book!
Dave.
Hmmm ... just opened both up and they're different ... not been inside one of them for a couple of years. The earlier one with the Woden Transformer seems to be outputting from the 3 ohm tap? might account for it sounding a bit different to the other as I've been running it into 16 ohms! The other is a 1964 and possibly has a replacement transformer, but it's quite a bit bigger than the Woden, it appears to be running at 16ohms, the vacant tap reads at half the value of the 15 ohm tap on my meter so I'm assuming it's 8.
The Woden transformer's Zobel network is as per the schematic, with what look like 2 or 3 watt wire wound 4.7k resistors and 0.002uF caps of a type don't know.
The other one has the network as well but it has 33k 1watt CC resistors and 0.022uF 400v Mustard caps!
Considering the differences in values, they do sound remarkably similar with the Woden transformer sounding a little quieter and perhaps a tad more polite when cranked, though if it is set at 4ohms that might be accounted for by being put through a 16ohm speaker?
The '63 is all Hunts caps with a couple of large Wima's and I've just noticed that all the black ones are all cracked :-S .. though the amp operates OK. The '64 is all Wima and mustard caps, with a couple of large red Hunts.
Feel I've taken a few steps backwards now. Suspect a visit to ICBM's headquarters is required.
1963
The black sheathed red and black wires go to the output jack
1964
The black gunge is most likely the result of the mains cap blowing sometime in the past.
Hunts caps were famous for going leaky/short in tellies (espc' IF amp decouplers)
Wimas were famous for going short in Grundig tape recorders.
Mustards are famous for never failing at all!
Dave.
I would like to follow Doug's findings up, one of the sensible audio guys! Do you have a link?
Re Zobel networks. A lot of cheap, IC based power amps use a really tiny resistor and under overdrive or perhaps a bit of HF instability it burns out, as it is often slammed up against the cap, it cooks that which shorts and the rest of the amp is history!
Dave.
Well, Zobel networks aside, I'd like to thank @ICBM who had a look at these at Lunchtime for me. The Woden transformer is 4ohm only and the other is 16 and 8 ohms. Not exactly what I wanted, but 4 ohms into 8 should be OK, certainly better than the 16 ohm cab I've been running the amp into for the past 2 years! Found a cathode electrolytic cap that looks ready to pop and a fair bit of remedial work to do changing all those peky Hunts caps, better warm up the old iron ...
