Drum machine repairs
I've found an old Alesis hr-16 in my garage but It doesn't seem to power up at the moment. Do you guys know of anyone decent who could take a look at it?
  • Probably an adaptor problem as opposed to the actual machine, check the one your using if I remember correctly the supply needs to be 12 v AC not DC but you'd better Google it
    www.maltingsaudio.co.uk
  • Could well be, I'll have a look into it.
  • FunkfingersFunkfingers Frets: 14496
    edited December 2021
    Could be that the lithium battery inside needs replacing. Tricky. I read that it is a Tadiran TL5101 3.6v half AA "P" terminal. The latter have to be soldered to the PCB. Approved Alesis repairers charge a fortune.
    Other members of the 51xx 3.6v series could be substituted if you were to attach the appropriate socket to the board first.
    I hope that your HR-16 only rquires a healthy PSU.
  • Hmmmmm, I've got a Christmas party to go to this afternoon then hopefully I'll get a chance to dig through my box of old power supplies
  • How did you get on?
  • marxskimarxski Frets: 250
    Those HR16s need a 9v AC supply.
  • I tried it with a 9v AC supply but alas tis still dead. Taking it to a repair shop looks like it the answer.
