A quick question about tab
LordOxygenLordOxygen Frets: 319
I'm in the process of learning a Guns & Roses solo and I could do with someone knowledgeable to explain what theses curved lines in the tab are indicating please?
Ta very much
  • sev112sev112 Frets: 2771
    They are slurs, you don’t pick the second note, so you play it by pulling off or hammering on
  • LordOxygenLordOxygen Frets: 319
    Thanks!
  • YorkieYorkie Frets: 1513
    Ah, so the part on the right would be like 12h13p12, but instead of drawing two arcs they've done just one?
    Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
    My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
  • fretmeisterfretmeister Frets: 24407
    It's normal to slur all of the notes in a slurred part. If there's a break between the slurs then that's where it would be plucked again. They could put a separate slur between all the affected notes but that wouldn't give a good indication of what that part was trying to achieve.
    Much better for it to say "right - for all the notes in the slur - slur them" rather than lots of little slurs just messing up the paper.
    Ah, I see, makes total sense. Thanks!
  • hollywoodroxhollywoodrox Frets: 4189
    Good one Yorkie and good luck with it, Slash has a great slippery style  ,very satisfying to play even at slower speeds when you’re learning it . I ve got to get back to my regular practice
  • PALPAL Frets: 540
    Best advice I can give you is don't use TAB because it's like painting by numbers develop your ears.
