Thanks chaps!… although if the ocd was there it would be more neat never happy but it’s getting better!…
I'd love to see a build process thread if you don't mind showing how the trick is done.
lovely job.
But start with the pots & jacks in the box, stick in the ground buss and build from that… worry about the power rail afterwards
Follow the circuit diagram… wouldn’t want to attempt it with anything involved tho’ don’t think I’ll be trying a klon and it does take up a lot of space in the box…
it’s just a case of making sure you have good mechanical connection before dropping a little bit of solder on there to fix it all…. It should all work without soldering tbh (apart from pots and jacks)
this is my second attempt at p2p…first is below.
Same circuit as the drive in the new pedal… new pedal has smaller electrolytics (needed tbh) and more places to go to ground so you can alter the layout slightly… to be fair you could prolly do away with the ground buss and just ground to the back of the pots…
as it’s all solid core (paper clips ) you can be a bit more creative with the routing…
That’s the input Jack… the plug misses everything and it will all stay out the way coz of the solid core… (you want solid solid core not the bendy stuff)
give it a go… bazz fuss is very low parts and should be easy…
just work the circuit out on a bit of paper!!!
Edit: here you go… bazz fuss you can layout as p2p
Edit again:
can tidy that up a bit more:
With that you can wire without being in the box
Nil Satis Nisi Optimum
Excellent. I've done a few on strip board but nothing like this.
the “PurpleRed”
sound great as well…
few clips in the link…
three examples per clip: clean amp - drive - drive and boost
Amp, guitar and pedal settings in the clip title…
sm57-logic no processing
https://soundcloud.com/user-931985443/sets/pedal-test
