New bass day
StuckfastStuckfast Frets: 2417
I've been looking for a cheap P-ish bass for a while and this seemed to tick all the boxes. Haven't had a chance to plug it in yet but it plays very nicely. And it's bright red. Wooo!
bass2.jpg 1.7M
  • GoFishGoFish Frets: 1419
    1) Yeah! Get yer Kim Deal on.
    2) Are those TM flats on there? Score if so.
    3)HNBD!!
  • Dave_McDave_Mc Frets: 2359
    Excellent! :D
  • StuckfastStuckfast Frets: 2417
    They're not flats, sadly, but they are nice and old.
  • ICBMICBM Frets: 72449
    That's *much* better than just a "cheap P-ish bass". It's a proper classic in its own right, very well made, and probably the best model in the range - the more expensive 1A active version had electrics which are probably best described as a bit dated now. You simply cannot go wrong with a P pickup, volume and tone controls.
    The intonation is off and the strings need putting on properly though ;).
    *rubs hands*
    Excellent! And it was cheap, so that's doubly excellent.
    Aha! It looks like it's been played left-handed. That would explain the weird intonation settings ;).
    Yes, someone has attached and then removed a second strap button on the other horn. Well spotted!
    edited May 2022
    You'll not get much past @ICBM
    Also I meant to say above, but I forgot, but the colour is excellent. I really like bright red in general (there's something "happy" about it, if you know what I mean), and you're right, it looks really good in that bass particularly. I think the gold sets it off very nicely, too.
    Well, I fixed the intonation, plugged it in and recorded some bass and I'm loving it so far. You can get such a range of sounds simply by varying the position of the right hand, it makes me wonder why any bass really needs more than one pickup.
  • fretmeisterfretmeister Frets: 24411
    BURN HIM!!!!
  • FunkfingersFunkfingers Frets: 14477
    Stuckfast said:
    it makes me wonder why any bass really needs more than one pickup?
    Somebody, give this person a copy of Jaco Pastorius' eponymous first album!
    ICBM said:
    That's *much* better than just a "cheap P-ish bass". It's a proper classic in its own right, very well made and probably the best model in the range.
    I'm so old that I can remember when Westone Thunder bass guitars first appeared. The originals were Sen/Ash in a natural finish. I rather liked that because it meant that there was no laminate hidden away.
    You are being far too kind.
    I remember the 1A treble and bass controls as - in the words of Vivian Stanshall - "sudden and alarming".
    Once the pots got cronky, the EQ was even less usable. Back in the day, the sensible option was to use the bypass switch.
    BURN HIM!!!!
    Ha, I freely confess to not being a proper bass player. But the bass this has replaced had two pickups and I struggled to get one good sound from it.
    Come off it. Even a Rickenbacker manages one good sound. :-p
    Come off it. Even a Rickenbacker manages one usable sound. :-p
    FTFY
    :D
    Wot? No bites yet?
    lol
    Actually I mostly agree... I rarely use anything other than the 'treble' pickup. I do very occasionally use the neck pickup with the tone turned down for that 60s thud bass sound, but I could live without it. (The treble tone has been converted into a rotary 'vintage cap' control, otherwise I could use that.)
  • AdeyAdey Frets: 2281
    Nice. I have an eye out for a similar one  but quite fancy black.
