Asking because the battery life in a bass preamp normally can be years. If it's not, there's often another reason.
In home studio usage, alkaline PP3s last years.
On instruments with onboard active electronics, the ring contact on the "stereo" TRS output jack acts as an on/off switch.
IIRC, the Cort has an EQ Bypass switch. You will have to be ready to engage that switch at short notice.
Depending on the exact pedal current requirements, removing alkaline PP3s from your bass to test effect pedals is a good way to drain them in double quick time. Digital delay, reverb and modulators eat batteries for breakfast.
The OP's problem sounds like a little short / leak somewhere.
Nard started with flats but moved to rounds in the 70s.
'What are some decent makes of rechargeable PP3, how long do they last between charges compared to alkaline, and who makes good chargers and battery testers?''
I do have some and I always buy Duracell ones, and for a first time buy you can get them in a pack with a charger.
To be honest - it's often more of a faff trying to find the charger. I get at least a year out of a PP3 in my main bass that has EMG pickups and an EMG preamp system. I put a sticker on the back of the headstock and write the battery install date on in pencil. I swap it every year no matter what.
I use rechargeable AA batteries far more often in my wireless packs. Duracell again, and going for the highest mAh capacity.
The charger for those is always available as for the wireless I get about 7 hours use per charge. Definitely sticking with rechargeables for that.
Be aware that some PP3 rechargeables are actually a tiny bit bigger than the normal ones. I've had some basses with the fold out plastic batter compartments where a rechargeable wouldn't fit properly!
