Withdrawn
jaymenonjaymenon Frets: 819
edited June 2022 in Parts £
Fender Hot vintage AlNiCo 3 Tele pickups, DiMarzio 36th Anniversary Nickel, Relic Tele Brass Saddles
Fender Hot Vintage AlNiCo 3 Telecaster Pickups £80
Neck and bridge
From a Highway One Texas Telecaster
https://i.imgur.com/7SXs16o.jpg
Heavy Relic Wilkinson compensated telecaster Saddles £15
Light Relic Slanted Telecaster Saddles £15
DiMarzio 36th Anniversary Pair Humbuckers Nickel £130
Purchased new a couple of years ago. There was a short somewhere along the cable between black and screen and therefore the black wire has been formally connected to screen (and red + green becomes the series connection).
Working perfectly.
Grover 305 Mid-Size Rotomatics 18:1 3+3 machine heads gold / ebony £40
https://i.imgur.com/PxRu655.jpg1959-1963 style
Pickguards
https://i.imgur.com/W8yjZOd.jpg
New Ibanez RG Hxx 1-ply black (Single humbucker) £9
New 1962-1983 style 11 hole Black 3-ply Strat Pickguard with countersunk holes for pickup / switch mounting screws and truss rod notch) £9
Used 1962-1983 style 11 hole White Single ply Strat Pickguard with countersunk holes for pickup / switch mounting screws) £7
Used Modern style 11 hole Black Single ply Strat Pickguard £7
Tortoiseshell Strat pickguard (neck cutout slightly widened to take a 57mm heel neck) £7
Plectrums
mix and match :-) 40p each.
https://i.imgur.com/hbjhr2B.jpg
Dunlop Jazz III Black 1.0mm Tortex (70)
Black Jazz III XL (18)
Dunlop Jazz III Black (32)
Dunlop Ultex sharp 2.0mm (27)
Dunlop Tortex Purple 1.14mm (and pretty much identical Fender 1.14mm thickness) (30)
Straps
https://i.imgur.com/Iq2On9w.jpg
Tom Anderson Leather £27
Identical leather strap - but without the 'A' £20
Black Poly strap £6
RotoSound Superwound Strap £6
SOLD
Bare Knuckle Stormy Mondays Set with Nickel Covers and 4 Conductor Wiring £185 delivered
Standard spacing, Nickel covers
https://i.imgur.com/zBVe1ZV.png
Iron gear Rolling Mill Overwound F-Spaced Bridge Pickup £23 delivered
https://i.imgur.com/1iebnMH.jpg
Monty's PAFs set in zebra, new / unused
£200
(plus delivery of your choice)
Standard spacing, Zebra, Never been installed
https://i.imgur.com/2LN9nqc.jpg
Genuine USA Fender Highway One Texas Telecaster Body (not the standard highway one)
£300
Swamp ash
Two-Tone Sunburst
Made in USA
Comes with an aged black pickguard
https://i.imgur.com/EiK5JXi.jpg
Fender USA Patent Pending Telecaster Bridge with Brass saddles & Ash Tray Cover, plus Control Plate and Knobs and string ferrules £60
https://i.imgur.com/Xk5tn0p.jpg
Withdrawn
Relic Tele pickguard £20
https://i.imgur.com/9P2YyR2.jpg
