The yard is nothing but a fence, the sun just hurts my eyes...
I prefer split usually - especially with a resistor - although for bass, parallel is better for some reason!
I don't like parallel for guitar pickups very much, it sounds a bit 'weak' to me - it has a slight flavour of the Strat in-between sound, for the same reason... essentially two parallel single coils, which produce harmonic cancellation.
A bit hotter than vintage.
Seymour Duncan JB with SSL1s
Bareknuckle Rebel Yell with SSL1s
Seymour Duncan PATB1 with PATB-Stks
EMG 89 (and 85) with SAs
80s Hamer (Made by Dimarzio) Slammer HB with Slammer Single Coils
Dimarzio PAF Pro with other Dimarzio early 90s single coils (in Music Man Silhouette)
I happen to like a contrast in output levels, but it's no hardship to use the volume control, or change pickup heights a bit if you wanted to.
One pickup which was a bit of a revelation was a Rio Grande Tallboy - thats a humbucker made up of two traditional designed singlecoils mounted and wired so you can have true singlecoil sounds when split and a decent meaty humbucker sound as well with the coils in series (I think in series).
I got one of these for an HSS strat project, and it did what was advertised - however it made me realise that I don't really like bridge single coil sounds - so it was helpful from that perspective.
Cheers,
Ben.
* Hamer Watson, SS2, Vintage S, T62.
* Music Man Luke 1, Luke II
Please drop me a message.
But the Les Paul was even better!
