OP, I see you're now after a Thornbucker.
I also agree. The Les Paul sounded nice and the guitarist here, Paul Drew, has some nice guitars.
Hopefully I can find a used 53mm one. Can't find any new ones in the UK at the moment.
I should probably clarify that I've never tried a Thornbucker, but it did (more or less) sound different in the way that any PAF-style pickups I've tried have sounded different from a hotter pickup like a JB. You don't have to go for a Thornbucker, in other words, just something with a similar spec. You can probably go under 8k if you want something as close as possible to the single coils (though still not that close, to be clear), or closer to 9k (or even slightly over) if you want to hedge your bets a little and still have one foot a little bit in the JB camp for heavier stuff. EDIT: Ah I see you just want to try a Suhr pickup since you haven't tried them before, in that case go for it (I don't think I've tried them either, I've only tried one Suhr years ago and I can't remember what pickups it even had!).
I preferred the Strat! I just like superstrats, lol (see avatar).
I just want an uncovered one. Black, zebra, or the off white (parchement?)
A few 50mm about but everywhere else is out of stock / awaiting delivery for ages.
I'm also looking at the DiMarzio Dual Sound in place of a Super D. for another project. Any thoughts would be welcome.
[This space for rent]
