Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Although I may end up buying SolidWorks, although I haven't got a CNC at the moment, I've just seen a demonstration of a small desktop CNC 9060 that comes in about £1800.
Also in the mean-time try and chase down a dimension - looking closer the distance between the two body wings across the neck through might be best because it is so sharp a contrast maple to rosewood(?) and it is perpendicular to the centre line. If not, calipers around somebody's Alembic pickups would do it too.
Instagram
Here I would also check the 24th fret to high E saddle, as it should be bang on 1/4 of the known scale length, +2 or 3mm for intonation.
i.e on a 34" scale bass the distance from 24th to saddle will be 8 1/2" + 1/8" compensation = 8 5/8"
Instagram
The pic above is not quite horizontal but a tiny rotation of 0.1deg anticlockwise got the centre line horizontal. It isn't super high res but it's got a lot of info in it and I think we have enough to get Graham what he needs. My initial fiddling:
I'm looking for another picture very similar that includes the 12th friend fret as the scale length is 30" I believe this hopefully will give us a much more accurate scaling of the body. I should also say it doesn't have to be an exact copy of the body lookalike will be good enough I think.
@jasonbone75 it looks like you will be able to do it, a PDF would be great.
Also useful was the 24th fret width at 2.15inch which I was able to scale with and confirm the 24th to E saddle as well. I'm pretty close to done. Just having issues exporting it as usual! Want to make sure it is 1:1 when you actually receive.
I'm not near SolidWorks from lunch today till Monday so if I don't finish I'll pick it up later.
OK think I've got something for you to try. This should be an A2 sized page with a 1:1 body in the middle. The centre line should measure at 330.30 mm when printed:
https://drive.google.com/file/d/1DLJwuu21Ug_609NSBwUwz4cVqz6perGR/view?usp=sharing
Once you've had a play come back to me next week in case we need to tweak anything.
JB
Although the customer who initiated all this seems to gone very quiet at the moment, but there's been a bit of interest in it as I don't think anybody makes any kits of this particular bass.
