Thanks again, I eventually got the chance to wire this up as shown above, however the single coils are barely audible compared to the humbucker. Any ideas what might be causing this?
The pickups gave the following readings with a multimeter:
Neck - 573
Middle - 605
Bridge (split) - 870
Bridge (full) - 1734
I have a push push (far better than push pull IMO) on the volume that puts the bridge PU in series with any other pickup . Very usefull volume boost and a more snarly tone.i them have a push push on the neck tone to coil split the humbucker set so that in the default position it is split. Up is full HB.
Now I deliberately got a Fralin Unbucker so the coil split is a little hotter.
This is the most versatile setup I have tried.
What are those measurement units? They don’t make a lot of sense unless the decimal is in the wrong place. They should be more like 5.73K, 6.05K etc.
If you’re rewire it again, it would also be better to flip the switch around so the contacts are facing the volume control - when they’re on the other side they’re more likely to short against shielding paint etc on the body.
Thanks again for your help mate, and apologies for the messy pictures!
The single coil tone control looks pretty clean and separated. As for the measurements, they were actually provided to me by the luthier who helped me build the guitar, but he is not as experienced with electronics. I might get a multimeter myself if that would help but assume you might be right with the decimal place. If that were the case, would those readings seem about right?
Lastly, regarding the switch, could it be that I've put that in the wrong way around and that is causing the issues or should it work either way around? (Other than potential shorts with shielding - FYI this guitar currently has no shielding).
If the decimal points are in the wrong places the readings could be correct, although I don’t think a JB should be quite that high. It is a loud pickup though…
Can have a go unsoldering the neck/middle tone pot. Do I only unsolder the middle terminal (connected to position 1 of the 5-way switch from the schematic) and leave everything else in place?
If you’ve swapped the sides completely it makes no difference. If you’ve connected the coil split to the resistor it will, but it will (very slightly) affect the humbucker and not the single coils.
Re the wiring, it is exactly as shown in this schematic. Should I swap any of the push-pull wiring around?
Did you mean green 4, red 5 (according to this)? ^
The wire from terminal 9 in the 470K resistor going to earth (on the other tone pot)
I am noticing quite a lot of hum which gets particularly bad if I touch the black wire from volume pot terminal 2 to the input jack but assume that might be normal?
If you haven’t tried it with the strings on yet, don’t assume what the output levels of the pickups will be.
Do you get a loud hum/buzz through the amp if you touch the pickup terminals on the switch (with the volume up full)?
It could well be possible. I am now armed with a multimeter (and the bare minimum of knowledge how to use it!) but I've determined the following values:
Switch position:
1 = Bridge
5 = Neck
Humbucker (Full)
Pos 1- 16.30
Pos 2 - 4.3
Pos 3 - 16.90
Pos 4 - 16.90
Pos 5 - 16.90
Humbucker (Split)
Pos 1 - 8.19
Pos 2 - 3.43
Pos 3 - 8.50
Pos 4 - 8.50
Pos 5 - 8.50
Neck Pickup
Pos 1 - 5.80
Pos 2 - 5.80
Pos 3 - 5.80
Pos 4 - 2.88
Pos 5 - 5.66
Middle Pickup
Pos 1 - 5.90
Pos 2 - 4.29
Pos 3 - 5.76
Pos 4 - 2.88
Pos 5 - 5.90
Pots
Vol - Terminal 1 - 3 (grounded) = 006k
Tone 1 - Terminal 1 - 3 = 260k
Tone 2 - Terminal 1 - 3 = 534k
My conclusion seems to be that the pickups and 5-way switch are fine but the 500k Volume pot might be broken as the reading is only 6k. Or is that just because terminal 3 is grounded?
Also are there any other connections / resistance levels I should check?
(Deep breath... )
The volume pot reads 6K from terminal 1 to 3 because the switch was in either position 4 or 5 when you measured it - you're seeing the pickup resistance, which is in parallel with it.
To check it's working properly, measure from ground to the middle terminal while slowly turning it from 0 up to 10. Keep the pull-switch down (off) and the pickup selector in the bridge position (humbucker) so the 470K resistor is disconnected.
What you should find is that the resistance starts at 0, reaches a peak of about 125K when the knob is at 7 or 8, then falls back to 16K(ish) at 10.
