I'm fascinated by this 'fusion' playing, can anyone dissect it for me?
  • GrangousierGrangousier Frets: 2644
    edited October 2022
    Also, fiddling some more and avoiding work, I realised that the higher of the two dominants is the flat five sub of the lower - with a bit of voice leading F7 - E7 - A major sounds very 19th century. For example:
    x        x        x
    4        3        2
    5       1        2
    3        x        2
    0       2         0
    x        0        x
    F7     E7      A
    Voice leading may be putting it a bit strongly, but there it is. No help at all with the widdly, but it's the sort of thing that entertains me.
  • vizviz Frets: 10715
    But Phygian dominant is the main one used in fusion after harmonic minor.
    Not a very learned person, but one thing I noticed when I tried this out is that if you add a note between the seventh and the root (there are reasons why you might want to do this) - in this case an Eb - you get two dominant seven chords a semitone apart - in this case E7 and F7.  Which also sounds good if you weave them together.
    Nice
