Of course the strings hold them in so there's no real need to fix them.
I've done dozens, possibly hundreds!
He just pushed the new string in and carried on. Then that string snapped a bit later, but the ball end was stuck. Same happened again and he somehow managed to string it past the stuck ball end.
I dug 3 of the buggers out.
Instagram
I've had a packet ever since and it's never been opened haha!
Should you glue in string ferrules? | Telecaster Guitar Forum (tdpri.com)
someone said he pushed them in with a hot soldering iron
I don't fancy doing that
Personally, I redrill the ferrule and string hole with a drill running in reverse as I don't want finish clogging up those holes.
Instagram
