Base Plate for Strat NECK pickup
I bought a couple of base plates recently.
I usually put them on the bridge position, but was wondering if it would give a bit more beef by adding one to the neck pickup as well?  I tend to use the neck pickup (position 5) fpr solos and some rhythm work, and  position 2 (bridge/middle) mostly for chords/picking.
Is this a bad idea or will it add a good bit of oomph to the neck positions as well.  Was planning on leaving the middle pickup stock.
Guitar is a 2003 USA strat standard, stock pickups.
  • FunkfingersFunkfingers Frets: 15276
    I suggest that you look into replacing those plastic-bobbined stock pickups before faffing about with metal baseplates.
  • ICBMICBM Frets: 74494
    +1
    Almost any decent, vintage-construction Strat pickups will sound better.
  • thomasw88thomasw88 Frets: 2374
    Ok that's fine. I usually change pickups anyway.   But in general how do people find a base plate on neck pickups?
  • robertyroberty Frets: 10932
    By turning them over and having a look ;p
    I =D>
  • normula1normula1 Frets: 662
    I'd just try it and see whether you like the sound or not. You only lose a bit of time and a little sticky tape.
  • paulnb57paulnb57 Frets: 3222
    Not quite on topic but I like a BK Sinner neck pickup with backplate at the bridge on a Strat
  • timmypixtimmypix Frets: 2554
    It definitely adds oomph, which does make it lose some of the classic Strat neck pickup delicateness(?), but if you're using it for gainy solos, I think you'd enjoy it. I've only tried a baseplated neck on BKP Sinners, which are already OTT, but it's definitely fun.
    Tim
