switch electronics
bitsbox
, for pedal specifics:
fuzzdog
for amp specifics:
modulus amps
Also ebay
I built a Tubescreamer once by scavenging parts from a broker PC speaker (opamp resistors, caps) , a tablet power supply (diodes) and a couple of parts of an old mixing desk (transistors)
Get yourself a basic meter and you can test diodes, transistors etc before you reuse them. You can make a lot of mistakes and it won't cost you any money.
Stick to older stuff for cannibalising parts as you want through hole components not surface mount for project building.
For all new build stuff for customers I use Mouser, CPC and RS as the pedal builder sites are more expensive
Bit bloody good you lot.
@tanihhiavlt I accept your kind offer and will pm my address. Sincere thanks.
