Modes...which chord?
HootsmonHootsmon Frets: 16056
Am I right in thinking that the preferred chord to solo over with G Mixolydian would be C?
Is C therefore considered the parent scale?
What wrong with the same G Mixo mode over a G chord instead?
This is where i get messed up with parent scales and applications
tae be or not tae be
  • octatonicoctatonic Frets: 33906
    This is where modes are fun, because you can actually play any of the major modes over a major chord, but it depends on what you are trying to say and where the chord progression goes.
    You can even play a minor pentatonic over a major chord- loads of rock, pop and blues music does this.
    The problem is doing it mindlessly and without specific intent.
    Always think 'what am I trying to say and why am I doing this'?
    To a specific point:
    'Am I right in thinking that the preferred chord to solo over with G Mixolydian would be C?'
    Sort of but not really.
    If you are playing over a C chord then the position on the neck might be around the 3rd fret, starting on the G but really you are playing C Major (Ionian mode).
    Try to think of 'positions on the guitar' and 'modes' as separate things.
    You can play any of the modes in any position... once you have learned to play them.
    Be directed by the chord progression.
    For imstance:
    Dm7, G7, C maj7 call all be played with D dorian, G Mixolydian, C Ionian... because they are the same notes.
    Playing a ii V I is not best done like this though- targeting chord tones is much better, especially the 3rd and the 7th.
    For example play melodies where these notes feature as landing points in your phrasing:
    Dm7 : F C
    G7: B F
    C maj7: E B
    It is a good idea to note how close these notes are to each other, such as a semitone difference between the minor 7th of the ii chord and the 3rd of the V chord. And the 7th of the V chord and the 3rd of the 3rd of the I chord.
    Now observe the notes that are in common.
    Dm7's 3rd is the b7 of the V chord.
    The V chord's 3rd is the 7th of the Cmaj7.
    This is all important.
  • rsvmarkrsvmark Frets: 1393
    I’ll play. The way it’s being taught to me is to also consider the ‘tonal centre’ of the song. So if your chord progression in a simple song is Dm C G, then while the diatonic harmony reference points point to the parent key as C major, the song sequence resolves to D minor each and every time you go around that sequence. So it has a minor feel. Try playing a C major based melody and it won’t sound right. Play a minor pentatonic or even Dorian at that point and it works.
    So while Your legitimate notes come from D Dorian, C Ionian and G mixolydian, it’s all the modes from the C major scale. In theory you ‘could’ play F Lydian (4th degree of the scale and 4th mode), A Aeolian (6th degree/mode) or even B Locrian…. But it won’t necessarily sound any good. @octatonic then makes the point my teacher told me, if you select the chord tones of the chord you are over at that point (he recommends 5ths as well), and select your notes so they are adjacent to the previous and the next one, your playing then becomes really melodic. I think this is called playing the changes and also my teacher calls it voice leading.
    But I defer to others with far more knowledge than me and apologies if I have given a bum steer.
    An official Foo liked guitarist since 2024
  • BradBrad Frets: 675
    edited March 2023
    No, the preferred chord to solo with G Mixolydian over is G and G7 (or any type of dominant chord).
    Yes, because G7 and G Mixolydian are derived from the C Major scale, they are related (share the same notes). G/G7 and G Mixolydian are the 5th chord/mode of the C Major Scale. But that’s not the only way to see G Mixolydian (or any mode for that matter).
    ??? Nothing… but it’s not quite that simple. It depends on the context.
    Don’t worry, this stuff is confusing at first.
  • HootsmonHootsmon Frets: 16056
    Well that's a start thanks. So, D Lydian is preferred over a D chord,yes?
    In simple terms, yes… kind of (that’s probably really unhelpful :smile:)
    D Lydian can be played over a simple D chord. But then so could D Mixolydian or D Ionian. It depends on the context that the D chord is in and even then, that’s not always the whole story.
    7ths and other extended chords give a clearer indication over what mode can be played over what chord. Using your examples;
    Lydian is for Maj7 chords - D Lydian over Dmaj7
    Mixolydian is for 7th chords - G Mixolydian over G7
    The confusion stems from how to view modes as there are a few different ways.
    Each of these modes has a parent scale. A major is the parent scale (same notes) of D Lydian (Mode 4 of A Major) and C major is the parent scale of G Mixolydian (Mode 5 of C major). This is the derivative approach.
    Yet each of these modes is an alteration of it’s own major scale.
    D Lydian is a D Major scale with a #4 (slightly different notes).
    G Mixolydian is a G Major scale with a b7
    This is known as the parallel approach.
    As @octatonic says, the intent is the important thing as much as knowing the how, what and whys. I can make the sound of a mode apparent without the need of an underlying chord. It’s about nailing chord tones and the tones inherent to the sound of the mode and phrasing.
  • vizviz Frets: 10762
    edited March 2023
    I want to play!
    For me, with all things keys & harmony, the first question to answer is: what is the root note?
    The 2nd is: is the song major or minor?
    the 3rd is: is it natural major or minor, or is it a weird modal major or minor?
    in your case, let’s say the song is “in G”.
    The following songs qualify for that:
    Dancing Days (Led Zep)
    I’m a believer
    Georgia on my Mind
    Evil ways (Santana)
    Vaughan Williams Fantasia on theme of Tallis
    Soldiers of Fortune (Whitesnake)
    All the above are written “in G”. The home note, the “tonic” is G.
    Next question: is it major or minor?
    The answer is given by the 3rd note in the scale. That tells you if the tonic chord is major or minor, and thus the song. Nothing more, nothing less. (I’m ignoring ambiguous tonalities.)
    The first three songs have a major G chord; the bottom three songs have a minor G chord. So Dancing Days, I’m a Believer and Georgia have major tonality. The other three have minor tonality.
    Major tonality:
    I’m a believer
    Georgia
    Minor tonality:
    Evil ways (Santana)
    Third question: is it natural major or minor, or is it modal? The answer to that is to examine the modal notes.
    If it’s a major tonality and has a raised 4th it’s Lydian. Dancing Days is in G Lydian.
    If it’s a major tonality and has a lowered 7th it’s Mixolydian. I’m a Believer is in G Mixolydian.
    Otherwise it’s pure, natural Major (aka Ionian). Georgia is in G Ionian.
    And:
    If it’s a minor tonality and has a raised 6th it’s Dorian. Evil Ways is in G Dorian.
    If it’s a minor tonality and has a lowered 2nd it’s Phrygian. The Vaughan Williams is in G Phrygian.
    Otherwise it’s pure, natural Minor (aka Aeolian). Soldiers of Fortune is in G Aeolian.
    (NB - other minor scales are available)
    There’s another test you can do, looking at chords rather than notes:
    If it’s a major tonality and has a major II chord it’s Lydian.
    If it’s a major tonality and has a minor v chord it’s Mixolydian.
    Otherwise it’s Ionian.
    And:
    If it’s a minor tonality and has a major IV chord it’s Dorian.
    If it’s a minor tonality and has a minor vii chord (actually a minor bvii chord) it’s Phrygian.
    Otherwise it’s Aeolian.
    That’s it. Simple as that.
    Sooooo. With your question, I think you’re asking, which scale should I play over a song that’s in G mixolydian. The first, most important and simplest answer is the G mixolydian scale. As you saw above, this is like the G major scale, but with a lowered 7th. It’s GABCDEF(G). If you were playing G major it would be GABCDEF#(G). But that doesn’t contain the lowered 7th of mixolydian.
    You actually wrote which chord should you play, and the answer to that is either a G major chord (1,3,5) or a G7 chord (1,3,5,b7), which gives you the lowered 7th. But definitely not a Gmaj7 chord. Other chords that harmonize with G mixolydian include C major, D minor, E minor, F major, A minor. But you really need to be playing a G chord of some sort.
    I think you’re also asking which is the major scale that contains the notes of the G mixolydian scale?
    All the scales mentioned earlier are relatives of the major scale, Ionian. Mixolydian happens to be the “fifth mode” of Ionian, so you need to count 5 notes downwards from G mixolydian to find the Ionian scale it’s the 5th mode of. You arrive at C major. The notes of C major contain the notes of G mixolydian. C major has CDEFGAB(C). G mixolydian has GABCDEF(G).
    Modes are really simple. The word DEMO is the 3rd mode of MODE. Same letters, same order, just starting on a different letter. Likewise, MODE is the 3rd mode of DEMO. You see that? In the same way, G Mixolydian is the 5th mode of C major. And C major is the 4th mode of G mixolydian. D Dorian is the 2nd mode of C major; it’s also the 6th mode of G mixolydian. OK, most people reference modes from a “parent” Ionian scale, but you don’t actually have to. Just understand that demo is a mode of mode, and mode is a mode of demo, and know the sequence of modes (Ionian Dorian Phrygian Lydian Mixolydian Aeolian Locrian) and you’ll be fine! Make a mnemonic to help you, something like I don’t fry leeks mixed with Aoli, look!
    0reaction image LOL 1reaction image Wow! 5reaction image Wisdom
  • I don't particularly like modes a lot.
    My trading feedback
    2reaction image LOL 0reaction image Wow! 4reaction image Wisdom
  • wizbit81wizbit81 Frets: 462
    What do you like?
  • sev112sev112 Frets: 2846
    @viz wiz for that bit about chords (ie if the 2nd chord of a major scale is major the it’s Lydian etc ) that is a really useful addition, and explains to me why I play lots of songs in Am with a D major chord :)  and the G minor in C :)
    Nice one, I agree knowing those standout chords is really valuable. We all play in the blues box, barring those G and B strings with our first finger and then two frets up with our third finger - that’s going from a minor i chord to a major IV chord - classic Dorian.
    What do you like?
    its a mnemonic
    My trading feedback
  • guitarjack66guitarjack66 Frets: 1987
    Rick Comiskey?
    Rick Comiskey?
    No idea who that is... sorry
    My trading feedback
  • CarpeDiemCarpeDiem Frets: 297
    @viz Your explanation is really helpful.
    Would you mind expanding on the DEMO / MODE point? Apologies to all those who understood it first time!
    The shift of the starting point..
    1) D E M O
    2) E M O D
    3) M O D E
    1) C D E F G A B C - Ionian
    2) D E F G A B C D - Dorian
    3) E F G A B C D E - Phrygian
    etc
    My trading feedback
    Thanks @bloodandtears - I understand now!
    Yikes!  THANKS tae everybuddy and Viz
    Lovely peeps one and all
    What do you like?
    its a mnemonic
    Haha so it is. That completely went over my head! :D
    Superb!
