So far most of my playing time on the Axe has been through a real cab. We've already discussed this but for the sake of this thread it just shows how different needs can be - for me the Axe has made my switching needs so easy that I can now perform some songs only using an expression pedal to go between high gain inc boost no delay, and low gain boost off plus delay.
With my own lead guitar tones, a certain mid range resonance is very important to whether they 'work' for me or not. If that certain something is there, other aspects of the sound are less critical. If I can get the guitar singing in a certain way, I immerse myself into the playing and play freely and naturally. If the tone isn't 'happening' then I struggle, it all becomes a bit 'forced'.
I think this is all a factor of developing your own tone and why, with experience, you can get that tone out of quite different amp/fx setups. As long as you can get the important elements of your sound happening you can make it work for you.
Time to get those b7k profiles I think, just sounds too good!
Again... I was finding (and no clips yet!) that the Kemper sounds more direct and in your face and fuller than the Axe FX. The more I use them both... the more a long-term preference for the tones seems to be emerging.
BTW: The delay and reverbs in the Kemper are brilliant. So is the rotary speaker effect. The tubescreamer is a bit crappy to be honest... doesn't really sound like a real tubescreamer to me. It's too gainy and doesn't really have the tightening effect that real ones do.
There's more than one way to amplify a guitar...
