signal chain
AJSAJS Frets: 43
Signal chain
 keeley compressor - zen drive (clone)- bad cat siamese drive (2 x klon klone in one box)
Its fine gigged like that for years
but a couple of people have suggested the siamese drive should be first
any comment greatfully recieved
  • SporkySporky Frets: 28715
    If that order works for you then it's fine.
  • Whichever sounds best to you is what you should do. There's no wrong answer.
  • AJSAJS Frets: 43
    Thanks guys
    deep down inside I guess I feel the same
    but i was curious if anyone a  had put a klon first
  • maltingsaudiomaltingsaudio Frets: 3145
    edited February 2023
    I would suggest when you feel brave enough to try the compressor further down the pecking order just to put your mind at rest! But as said befor there is no right or wrong if it works for you.
    www.maltingsaudio.co.uk
  • GramPGramP Frets: 3
     Of course its wrong! have you never read Buckleys'  " Order of Signal Chains  in an electric filterless circumaural environment" that explains everything.. it is possible that having the Zen drive ahead of the Siamese drive is  breaking the the second law of nonthermoaascoustodynamics,, and you will get reported to the MU, lose all you  musical rights and be consigned to  performing... Hot  August Night 6 nights  a week in an over 60sl ine dancing club for three years
