SOLD FS/FT Fender 2011 AVRI 72 Telecaster Custom £1350 NOW £1250 ANY TRADES CONSIDERED SOLD
I bought this guitar off this forum about 22 months ago from 'wiggyweston'
72 Tele Custom reissue, AVRI from the first year of production I believe (2011). This has the period-correct ash body, whereas the newer models are made with alder. It has also been modded with a Certano palm bender! This allows for B-bender style effects on the B and G strings. As part of that mod, the bridge was swapped out for an Allparts Bigsby plate (to allow the strings to pass through to the bender) and Gotoh brass saddles were added. The originals will of course be included.
It has a small crack in the scratchplate, by the Wide Range humbucker in the neck. It never bothered me enough to change the scratchplate. There is also a mark on the back below the neck plate where the nitrocellulose has reacted with the rubber on a guitar stand
This has all its case candy included—the strap, cable, and ashtray have never even been used This is such an excellent guitar, and a really good buy for someone who wants to try the palm bending thing.
Comes with an immaculate C and G case. No fret wear to speak of.
I am open to trades for:
Eric johnson stratocaster
Deleuxe reverb 2 or a silverface Deluxe reverb but may consider other amplifiers as long as they are 1 x 12 combos
Nordstrand Acinonyx Bass
30inch
USA straocaster HH or HSH or HSS
Price drop to £1250
The eagle eyed amongst you will notice only one lever on the bender. I only use the B bender. Brad Paisley only uses a G bender.
The lever is in the case.
I have had a nightmare trying to photograph it as the only camera we have a is an old 8 meg compact
https://imgur.com/a/Lbs4mas
Regrettably, all of my Fender USA Stratocasters have SSS routing and rosewood fingerboards.
Like them a lot but I still like a full sized super distoprtion as my bridge PU
