https://fretboardanatomy.com/picking/
Edit: Stupidly forgot to mention Martin Miller’s JTC box set. Specifically the picking one! But they’re all worth the price of entry; fantastic guitarist and pedagogue.
Like the OP I played using my thumb and fingers. That’s because I wanted the ability to play bass, melody, and harmony at the same time. It was only when I joined a covers band that I had to start using a plectrum to get the sound, and the rhythmic content, which many pop songs need. Basically “All The Small Things” wore through my index finger nail in the course of a rehearsal. Since then I’ve experimented with different plectrums, and different ways of holding them. George Benson’s method works well for the type of music Benson plays, but doesn’t work so well when you need repeated downstrokes and palm muting.
https://m.youtube.com/watch?v=AfVYSruxFG0
I scan-read the 'fretboardanatomy' article and I didn't see any treatment of string-crossing. A 'George Benson grip' looks like it's pretty committed to an 'upward escape' motion in CtC terms...if you only escape the string plane in one direction, you have to arrange what you play to support this: do you start on an up or down stroke, do you play an even number of notes on each string, do you drop in a hammer/pull-off to get you out of bother, etc.
* I did crowdfund the development of 'The Magnet' though
I pursued it (the GB technique) years and years ago, but bailed as it was like relearning the entire instrument. However in the last year or so, I’ve sort of morphed into it because of mild discomfort with the ‘traditional’ grips, so I’m getting the hang of it. I feel I have a much better control over the dynamics and the only thing that I was worried about was the adaptability to exactly the sort of rhythm playing Henry was doing above!
There's quite a few things you can do with hybrid, even in a shredding context which would be very hard to do with just a pick.
https://youtu.be/1Qb5IR_Vo3o
The main thing IMO is getting the motion right. None of the other stuff matters if you are making bad movements
This helped me towards my first breakthrough:
I learnt Bark at the Moon by Ozzy Osbourne around this time which is a great exercise as it is mostly pedalling 16th notes on the open A string. The palm muting means you are forced to have a good motion as your wrist is low
The other thing that helped was Cracking the Code, but I didn't go into any great detail with it. Just knowing the escape paths is enough IMO
Another thing I would suggest is to feel the pick pass over the string and allow the pick to do the work. With the right angle the tip of the pick should glide over the string nicely and make it pop
My playing got worse before it got better as I incorporated these new techniques into my normal playing, it was quite a gruelling experience! But I'm glad I did it
Good luck
And again: yep...when I'm under pressure legato creeps in...then some economy picking...then hybrid picking. I guess this is the true *me* at this point in time and, obviously, that changes very gradually with focused practice.
That point about 'relaxed practice' is a core CtC thing (as you'll know @roberty ): the speed pushes you out of your comfort zone and makes you find a flatter, more efficient picking-hand action. Either side of that line, you could still be alternate picking...but the relaxed version is bouncing/arcing all over the place...I like that feeling as you can think more about articulation. The thing I'm always rethinking/overthinking are anchor points!
I went through a few tutors as an adult, and the one I settled on was perhaps not the best teacher but I loved his playing and I really wanted to play like him. Every week I'd watch him play certain things that seemed impossible to me and think "how tf did he do that?", and although he wasn't able to properly explain I was determined to figure it out
I think you need that sort of target to focus your practice and make it matter, I certainly do anyway if others do not
*edit: not while they are on the toilet
If you watch this from 19m:20s or so he has the best way of describing the difference between learning, practicing and playing:
You need to apply a different mindset to each activity, because applying the wrong mindset to the wrong activity will destroy your confidence
There’s a heap of courses and interviews etc so I’ll have a look and see.
https://www.soundslice.com/slices/cjZDc/?from=channel
