Best desktop modelling amplifier (for me)
My requirements are fairly simple:
Fender Blackface Cleans
Dumble / Mesa style overdrive
there’s just so much to read online and it’s very confusing. Would someone please advise me…?
  • Winny_PoohWinny_Pooh Frets: 7943
    edited August 2023
    Built in speaker or no?
    I have a BOSS Gt-1000 core. Small, sounds great and has extremely low latency compared to other sub £1000 modellers.
  • TTonyTTony Frets: 28221
    You do realise that you're about to get recommendations for at least 10, completely different, options?
  • ReverendReverend Frets: 5266
    Obviously you need a full Marshall JCM 800 stack. And BC Rich Warlock. Hope that helps
    8reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • If you already have computer based recording then you won't get much better sound and tone options than the Scuffham S-Gear package. I tend to use the Overloud TH-U package due to the higher gain options! There is no denying the quality though. Both are fantastic for home use and rival any hardware units (with the caveat your host machine and audio interface must be up to snuff).
  • BluesLoverBluesLover Frets: 693
    I have a BOSS Gt-1000 core. Small, sounds great and has extremely low latency conpared to other sub £1000 modellers.
    Do you play this through a powered monitor, or something else?
    Boss Dual Cube LX might be worth investigating, as an all in one desktop solution.
  • jaymenonjaymenon Frets: 872
    edited August 2023
    These hardware digital modelling amps have latency?
    I think I'll stick with my amp.
  • thecolourboxthecolourbox Frets: 10166
    Well I think they all will to some extent, but then also so will standing different distances from an analogue amp. I don't think it's problematic to be honest (unlike the latency you'd get on a computer plugin where the machine wasn't up to the job, for example)
    Taking part in 1000 Lights - raising money for Uprawr Mental Health Foundation
    https://www.justgiving.com/page/pianomatt-1000lights
  • MusicwolfMusicwolf Frets: 3732
    Hi Jay (and belated Happy Birthday for earlier in the week)
    Unless you are sitting with your ear pressed against the speaker cone (not recommended) then your amp effectively has latency due to the speed of sound.  Even if you are only a couple of meters away, at approx 330 m/sec you will experience latency of around 3 ms.  I have both a Kemper and a Helix and additional digital latency is unnoticeable.
    The big question for anyone considering whether to stick with a 'real' amp or go down the modelling route is - can you live without that amp-in-the-room experience?  Until recently I owned a 50-year-old Fender Pro Reverb which sounded unbelievable, or at least it did on the handful of occasions that I used it due to the practical constraints of volume at home / amount of boot space taking it to rehearsals.
    Thank you Chris for taking the trouble to write such a long and detailed message.
    Distance from the speaker:
    Yes this is something that I hear often. However, whatever system I use I tend to sit at the same distance from my speakers. The latency that the system imparts, comes on top of (and in addition to) the latency created by this distance. With certain interfaces it has been really troublesome for me…
    As for home use, I use this lovely 0.5 W amplifier (below) which sounds phenomenal.  However, with an overdrive pedal, it can still become rather loud.  So at the moment I’ve hooked up a Sequis  elemental on a bypass switch, which I bring in only for overdriven sounds.
    Add to that a microphone in front of the speaker leading to a stereo effects processor given me 100% wet modulation effects through a pair of studio monitors on either side of my 1×12.
    … and it gets a little complex.
    However, it’s a lovely little system and once set up it works beautifully.  It just made me wonder though if there is a single little amplifier that I can plug into which will give me all the sounds at a controllable volume :)
    Not relevant to anything in the thread really, but that last photo is a very satisfying looking setup.
  • You should have lead with that post! Given all that gear already and your obvious content with the results just add a load box with IR built-in. All volumes plus headphone option and all of your rig sound.
  • rossyamaharossyamaha Frets: 2462
    Obvs the original and still the best. Yamaha THR innit. Does all the things and looks nice too.
    If playing into a pair of studio monitors IMO the Boss Gt-1000 core or Fractal FM3 will sound better than the little amp (but perhaps not as "alive" as the little amp into the 1x12).
    The benefits are in just having one cable and lots of great amps and effects. You can also travel, move it from one room to another and use headphones.
    Unless money is an issue buy and then try. I use my modeller at home alongside two Great valve amps as well as for an effects unit when gigging acoustic.
  • flying_pieflying_pie Frets: 1836
    edited August 2023
    Everything has latency. Guitarists have just forgotten about basic high school science.
    Consider the speed of sound through air is approximately 340 metres per second. If you are on a stage 3m away from your amp then the latency in terms of how long it takes the sound to reach your ears will be 0.0088 seconds which is rounded up to 9ms. That's the lowest it can possibly be and it's likely a little more as there's bound to be additional latency in your signal chain. But that's not going to be something you'd notice.
    There seems to be an internet idea that it's only possible to play guitar with zero latency and anything else is unacceptable. I've seen people complain about 3ms latency which is utterly crazy. If that was true then they wouldn't be able to play their guitar properly more than 1m away from their amps!
    Edit - sorry I missed the earlier post by @Musicwolf ;
  • jakeollyjakeolly Frets: 121
    Ive never thought i was bothered about latency and have have had loads of digital modellers, but they always left me a bit ‘cold’ either thro getting drawn into ‘ unlimited possibilities knob twiddling’ or them just not feeling right
    Then i tried the a DSM & Humboldt Simplifier. It immediately felt and sounded better to me  (and its defo not because Ive got bat ears)
    Worth a try imho
  • Johnny333Johnny333 Frets: 171
    For incredibly accurate DAW amp tones I'm super impressed by the Neural Amp Modeler. It's an open source free software using machine learning that's being constantly updated with new features by the community.
  • Power-BeefPower-Beef Frets: 214
  • My trumps have latency , it’s quite a few milliseconds from when it leaves your arse to smelling it
  • birtnerbirtner Frets: 68
    vox adio has a good blackface mode and also a dumble and mesa option. And it looks like a handbag. It’s win win
  • stickyfiddlestickyfiddle Frets: 28141
    Big fan of the Yamaha THRs for simple plug& play boxes.
    They take pedals nicely and can also be set flat/neutral if you want to use them with a modeller in front - I use an HX Stomp exactly this way
