SOLD - Tele, bits and pickups
Guitarbuild tele deluxe body with Fender hardtail bridge. Epiphone P90s - from a 56 pro. Custom made matt black pickguard from earplanz(?) of ebay fame. Can thrown in the pots from the epi too if wanted. This is a project that is just not going to get done (one of many). So I will offer it up as a bundle and see if there is any interest. The body has been routed to take any pickup. I had JM pups in there at one point. I started stripping the body but got distracted so its a partial blank canvas for someone - £110 delivered. (Fender neck plate not inc)
I also have an allparts large headstock, bullet trussrod, rw board neck, if interested... perfect match for this build..
Tele firebird/mini hum bridge plate. Pretty hard to find one of these.
@funkfingers was/might be interested in this. £35 delivered.
WITHDRAWNSD Seth Lover neck pup - extended with cloth wire. £75 + p&p
70s F Style tuners never installed £42.50 delivered!
SOLD
Schaller STM Roller Bridge: £35
SOLD Oil City HB sized Filtertrons (no screws). £80
SOLD
what size are the post holes? what’s the radius? and how far apart are the post holes?
The Schaller STM tune-o-matic bridge has roller saddles to keep the strings perfectly in tune after bending, especially useful with Bigsby style tremolo tailpieces. The saddles are individually intonatable and also adjustable for customer string spacing, simply rotate the roller saddle along the threaded support bar to set the position of the saddle. The roller saddles have a larger slot in the low EAD strings and a thinner slot in the high GBe strings for the correct support. The whole bridge is constructed at a slight angle so that when the bass side of the bridge is angled back away from the nut (as standard on Gibson Les Paul and most tune-o-matic guitars for additional intonation room) the roller saddles are straight, pointing towards the nut, this ensures the strings glide over the roller saddles in a straight line and not at an angle. Supplied with 5 mm Nashville style bridge posts and body anchors/bushings.
lollar dogg ear P90’s?
Are they neck and Bridge?? Cheers
