This is the 99th solo of the Month (SotM) Challenge.
You can download the backing track from Soundcloud below:
https://soundcloud.com/thefretboard/sotm99-digitalkettle-eikositriophobia?si=863ec432cd9b4ea787d906cbee4b9542&utm_source=clipboard&utm_medium=text&utm_campaign=social_sharing Title: Eikositriophobia (who'll spot the reason for the title first?)
BPM: 105
Structure/Chords:
• ( | Eb F | Cm9 | ) x 3
• | Eb F | Cm9 | Cm9 | Cm9 | Cm9 |
• ( | Cm7 | Cm69 | ) x 6
Record your solo over the top of it and then submit it (ideally in mp3 format) to solos@theFB.co.uk
Also, feel free to comment on how you approached the solo, which will add a bit more interest and maybe we can learn something from each other.
There should be headroom to record your solo. Try to set a level without excessive master limiting, because we want to avoid loudness wars.
Voting will start soon after the submission deadline, with each voter selecting their 1st, 2nd and 3rd choice.
First choice gets 5 points - Second choice gets 3 points - Third choice gets 1 point
The order and scores of the top three entries will be announced soon after the voting ends.
No prizes. It's just for fun.
As people submit their entries, I'll post them below to hopefully promote some discussion on approaches used for the solo:
There's usually a certain amount of planning (drop-ins etc) with my entries and I suspect with a few other entries.
I searched up mode and scale images looking for the patterns I played and Dorian looked closest.
Feedback thread: https://www.thefretboard.co.uk/discussion/comment/3575378
I was using Dorian and probably the natural minor too.
Anyway, the recording was a Strat with tone rolled off and on neck pick up for first two sections and switch to Bridge for final section. Mesa Amp modeller and all the usual effect trimmings
It's in the playlist.
Well, if it counts, I think I played 23,000 takes before choosing one.
