Hi all,
You may recall I built my first amp, a 5f2a from a modulus kit early this year. I'm now slowly coming around to the idea of playing with the odd mod and fancy trying a combined negative feedback / cathode bypass cap as per the Rob Robinette diagram linked here:
https://photos.app.goo.gl/fp1P68spF4oZVcac9I've got my head around how to approach this but have one concern. Currently the bypass cap and cathode resistor are mounted to the same turret at each end, as per the modulus layout. To make them switchable I need to split them at one end and Rob's diagram shows them on separate turrets. To remove the board now and add an extra turret would be a lot of work so I wondered what the best way is to go about splitting one of these off the turret? Could I just splice a wire onto the end of the resistor for example, or is that deemed a bit sloppy? Or is there another way to add a turret without removing the board?
I hope that makes sense!
Thanks,
Graham
