line 6 dilemma..
  • I'm in two trib bands so versatility is key; Metallica and AC/DC sure have different sounds.
    They don't when I play them. :)
  • ICBMICBM Frets: 74500
    Have you tried setting the Valvestate to 'Linear' instead of 'Valvestate'? That should (I think) tighten up the bass response. Unfortunately it might also change the sound of the patches you do like normally too.
    On the other hand that 8004 is really a piece of crap, and if you're worried about valve reliability...
    I would maybe think about changing it for a 8008, which is a far better-engineered, better-sounding and more reliable unit.
  • It is on linear...
    My trading feedback
    Setlist notes:
    For whom hells bells tolls
    Back in Black album
    Ride the thunderstruck
    It is on linear...
    Try Valvestate, you never know! I suspect it will be worse, but I could be wrong :).
  • Ok, so last I tried all sorts of power amp options last night.
    Pod Pro ->
    Samson Servo 170 / Crate Power Block / Valvestate 8004
    --> Marshall 1966a/b 2x12
    All were pretty much the same probably more headroom on the valvestate and power block though.
    I also tried a Blackstar ID100 through the same speakers.
    Any low E palm mute chug on a treadplate patch has a brutal thump... the speakers dont seem to flap or abnormally distort or "fart", so could I just be witnessing "the norm"? The movement of air?  I have been so use to a certain sound that perhaps I need to experience some alternatives.
    Its certainly usable at the moment just got me thinking.
    The Flextone 2 HD I had died back in May, and since them I have been using a Bogner Spider Valve; perhaps my ears have forgotten what the Flex sounded like?
    My trading feedback
    The low-end is supposed to be pretty boomy on a Rectifier, yes. I assume from what you were saying that it was overdriving the speakers, but if it isn't then it's probably normal for that patch.
    A friend of mine has a similar problem with a real Rectoverb amp, it booms on palm-muted chords when set to the heaviest type of sound. I tried curing it by adding a bit more damping to that mode, but it took away what makes it sound like it's meant to! He just learned to work around it eventually.
