Which were your go to profiles?
As for the clean tone stuff I had a mess around using the clarity/definition controls. It makes a difference! Also using the amp setting compressor as opposed to the pedal effect makes it sound better. Using a Michael Britt 74 Champion one (one of the stock ones) and fiddled around. Sounds nicer than what it was though just need that mid range in there as its a bit bright.
However, I found the dirt pedals a bit rubbish.....and also I had a weird bug where the whole thing would randomly sound like a cocked wah had been placed in there somewhere. Sometimes even a complete factory reset and restore wouldn't fix it....or would fix it the 3rd or 4th time.
I mentioned this recently on the public Kemper forum and nobody had heard of it.....but I have friends who have experienced the same thing.
Anyhoo....I am playing with the idea of going back and wondered if much had changed. I also wondered about reducing the form factor by using a Kemper Stage but remember lots of gripes when it first came out about reliability and hardware issues?
Finally, the age old 'Kemper 2' - I wouldn't want to get a Kemper just as a new version is coming out....
Each to their own but I own a Kemper Stage (my second Kemper). It's rock solid and I've gigged it about 300 times. I've never experienced the problems you have but I may just be lucky.
Has much changed? Well liquid profiling is new and works well. To be honest with the right profiles I never have to resort to dirt pedals and for me it's perfect and sounds great.
As for Kemper 2 - nobody has any idea, but if one came I'd still be happy with the one I have is it just does everything I need.
This was recorded using one of Bert M's SLO liquid profiles..
https://www.thefretboard.co.uk/discussion/258015/hamer-chaparral-custom-1986-alan-murphy-style-demo#latest
Si
Also its taken me 3 years to realise turning off the power amp in the output sections stops the unit from heating up after prolonged use.
I got everything else, Strat neck pickup etc. What am I missing? Mid gain? Preamp gain? More compression? I've tried doing all these but can't seem to get that "spack" sound. Or am I simply not hitting the string hard enough on the backbeat haha.
