Just a thought.
Shame, because I'd like a looper as well - I think it would make a really useful addition to a practice amp.
EDIT: @pt22 the sound generation software of the Spark isn't running on the phone. It does use the phone to play backing tracks (and the utterly useless auto-accompaniment gimmick) but otherwise the phone app is purely used for configuring the Spark's internal modeller.
i guess it’s like pt22 said though it would have to work on a lot of low to high end phones & people with low end would be left out
To exaggerate the problem, imagine the bluetooth link had a 10 second delay. Playing a backing track would be fine - you'd press play on the phone and 10 seconds later it would start playing on the Spark. Then you would just play along with it as normal and not care about the delay. But if your guitar signal was routed via the phone so we could use a phone-based looper app, then when you pluck a string the signal would have to go from the amp to the phone then back again before you hear it - so with our fictional ridiculously slow bluetooth that could be 20 seconds before you hear the note - obviously unplayable. Real-world bluetooth latency will only be in the couple of hundred milliseconds, but that is still enough to make a pretty terrible experience with live sound.
So I think any additional effects would have to run directly on the Spark hardware - and I suspect there isn't enough memory for a decent length looper buffer. If it were doable I'm sure they would have done it by now.
But I'd love to be proven wrong - a looper would be very useful.
The auto-accompaniment part of the app is running on the phone and the experience probably does vary (from utterly useless to just not very good
Which isn’t really much good.
on looking at one video ,yes the built in mic
https://youtu.be/qZ9Euux5lRE?si=Ad0fI7ytT4G6O_eN
I suppose the best thing would be to have an fx send receive to plug a normal looper pedal in
https://youtu.be/IcIa55u90MM?si=WHbUaiCuCob-iSvh
Otherwise you do need an fx loop, which obviously the Spark doesn't have.
