what about this?
vizviz Frets: 11043
May be an image of guitar and text that says M TONE 2 M 3
  • ICBMICBM Frets: 74503
    Looks like one of the sort of things Ritchie Blackmore would do just to make people ask why he did it...
  • SteveRobinsonSteveRobinson Frets: 7344
    Needs a Switchcraft jack
  • stickyfiddlestickyfiddle Frets: 28753
    I only see the point if it’s to facilitate a 9V battery without routing anything
  • Winny_PoohWinny_Pooh Frets: 8078
    edited January 27
    Good chance of the jack or socket grounding itself on the inside wall. Not a great mod
  • SporkySporky Frets: 30228
    Maybe it's for dispensing some sort of sauce.
  • Dave_McDave_Mc Frets: 2462
    You mean like the medieval music?
  • JonathangusJonathangus Frets: 5057
    Works fine if you're normally a Les Paul or Tele player who uses an angled jack.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
    So does a standard Strat socket. I always use right-angled plugs. With a Strat it actually points the cable up at just the right angle to go straight under the strap.
  • BillDLBillDL Frets: 9018
    edited January 28
    I think it looks quite smart, but only if a nut or washers had been used on the inside to leave the end of the threaded collar level with the external nut   I'm going to swap all of my Strat-like guitars around like that.  I'm also going to make extension collars so that the Electrosockets on my Tele-like guitars stick out from the sides.
