A little mod
GSPBASSESGSPBASSES Frets: 2398
edited April 16 in Making & Modding tFB Trader
That can make using a trimming router into a plough router. I’m sure many of you have got these little trimming routers in the workshop. Great for what they would design for, but when it comes to using them as a plough router, adjusting the depth is a pain in the backside. I come across this router lift for use on a router table. Very sensibly priced, I ordered one, as I thought they could be used the other way round. I was really surprised at how well it was made, considering the price, under £30. And yes, it could be used the other way round, see the photos below. I only wanted to modify the routers I used when I radius fingerboards.
 You'll see, I've added an extra nut to lock the two together, so I can use a 10mm spanner to adjust the height of the router.
This is a link to where I purchased it from.
https://www.temu.com/uk/1pc-woodworking-precision-router-lift-aluminum-router-table-insert-plate-kit-wood-router-lifting-base-for-working-benches-diy-tool-g-601099516830363.html?top_gallery_url=https%3A%2F%2Fimg.kwcdn.com%2Fproduct%2Fopen%2F2023-04-28%2F1682666955411-64b5d1ac29d94485896f928cc98988cf-goods.jpeg&spec_gallery_id=24260631&refer_page_sn=10009&refer_source=0&freesia_scene=2&_oak_freesia_scene=2&_oak_rec_ext_1=MjY3OQ&search_key=woodworking%20tools&refer_page_el_sn=200049&_x_sessn_id=6byvjr52pz&refer_page_name=search_result&refer_page_id=10009_1706359225052_vqlsbn9w14
0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • Andyjr1515Andyjr1515 Frets: 3129
    Great tip and tip-off @GSPBASSES ; Thanks!  :)
  • ICBMICBM Frets: 74503
    Sorry. Could not resist :).
  • FunkfingersFunkfingers Frets: 15283
    Beaten to the punch AGAIN!  :#
