FS/FT: Milkman Boost, Catalinbread CSIDMAN, Nordland ODR CC+, Moodysounds Carlin Compressor & Fuzz
DoveholesDoveholes Frets: 137
edited 10:23AM in FX £
More photos here. Trades-wise I am after a Source Audio Zio.
Moodysounds Carlin Compressor (and fuzz) - £55 Posted, PP F&F
Rare and unique compressor & fuzz pedal. As used by Dungen and Kikagaku Moyo. No original box, velcro on the bottom. The handpainted finish is quite uneven but adds to the charm.
From Moodysounds...
"The collaboration with Carlin actually began when a customer contacted us and asked if it was possible to make a clone of the classic, Swedish-built compressor. I contacted Nils Olof Carlin and he was very helpful in answering questions, giving tips and advice on how to build a clone. It also turned out that he had about ten shells and cards for the compressor lying in the attic and a new production was immediately started on a smaller scale (they were sold from this online store in 2013 but they are sold out now). Read more about the reissue of the Carlin pedals and an interview with Nils Olof in fuzz.se. When the newly manufactured pedals ran out, a new board was drawn and the original circuit was cloned. We made some layout changes (see below) but the audio part itself is identical.
The special detail of the Carlin Compressor is that you can mix overdrive into the sound. Namely, the pedal has, in addition to the Sustain and Volume knobs, a knob for Dist. If Dist is turned down to zero, you have a clean tone with fairly mild compression, which blends in nicely without sounding artificial or "too much" at all. If Dist is turned up a little, you will find sounds that are absolutely perfect for solo playing and that give just the right hang on the note.
For those who want to tinker technically with the sound, without going all the way and building a kit, we mention the trim pot that is on the card. In short, it can be said that it sets the range in which Dist and Sustain operate. When it is built here, it is set to our liking. You can try adjusting to give the pedal more or less Dist and Sustain in the sweep."
Nordland Electronics Compact Overdrive ODR CC+ - £180 Posted, PP F&F
Boxed as new, apart from velcro on the bottom.
Catalinbread CSIDMAN - £120 posted, PP F&F
Killer glitch pedal in excellent condition. No original box but will be carefully packed. I've tried most of the random/glitch pedals currently available and this one is right up there with the best. It has sounds that can't be achieved on some of the others. Highly recommended.
Milkman Pop Top Boost - £145 Posted, PP F&F
The cleanest clean boost I have ever tried! Headroom for days. Boxed as new, apart from velcro. More pics here.
"The new Pop Top Boost from Milkman Sound takes its inspiration from the classic American recording consoles of the 1970s. We designed a discrete Op Amp which fits the standard 2520 footprint and put it into a modern pedal enclosure for use with guitar or any other instrument that uses 1/4” phone connectors.
The Pop Top takes power from a common 9V center negative pedal power supply and converts it to 36V of internal headroom (that’s more than a tube has!). This unusually large amount of headroom has many practical uses ranging from a 30dB clean signal boost, a unity gain buffer with midrange focusing detail, or a line driver.
We designed the Pop Top to run at “unity gain” with the control set at zero. At unity you can hear the discrete op amp color and find a sweet spot without dropping any signal. There is enough headroom inside to use the Pop Top at the very end of a pedal chain even in tandem with other gain and boost pedals.
As a preamp, the Pop Top can enhance the subtle details of the source in the same way that a microphone preamp in a classic American recording console would. In the 1970s discrete op amps were designed to be used at the input and output stage to both preserve detail and slam magnetic tape with as much signal as was necessary to capture the sound. The Pop Top is designed to inspire some of that same magic and creativity from the world of classic record production but in a much more guitar friendly package."
Zvex Double Rock - £170 Posted, PP F&F (SOLD)
29 Pedals Euna - £200 posted, PP F&F (SOLD)
Boss FZ-1W - £120 Posted, PP F&F (SOLD)
Bondi Effects - Sick As (High Shredroom) - £165 posted, PP F&F (SOLD)
Benson Germanium Boost - £130 Posted, PP F&F (SOLD)
Line 6 HX One - £190 posted, PP F&F (SOLD)
Black Arts Toneworks Pharaoh Supreme - £140 posted, PP F&F (SOLD)
Origin Effects Revivaldrive Compact - £185 posted, PP F&F (SOLD)
1981 Inventions DRV - £180 Posted, PP F&F (SOLD)
Earthquaker Devices Hoof V2 - £110 Posted, PP F&F (SOLD)
Dinosaural Cogmeister - £280 posted, PP F&F (SOLD)
Frost Giant Electronics - The Mountain V3 - £115 Posted, PP F&F (SOLD)
Analogman Sun Bender MKIV - £295 Posted, PP F&F (SOLD)
Eventide H90 - £700 Posted, PP F&F (SOLD)
Wren and Cuff Forest for the Trees BM20 Ultra - £220 Posted, PP F&F (SOLD)
ClinchFX Pico Pre (Always-on Clinch FX EP Pre Echoplex EP3 Preamp) - £125 Posted, PP F&F (SOLD)
Analog Man modded EHX Deluxe Memory Man XO MN3008 - £335 Posted, PP F&F (SOLD)
Kernom Moho - £269 posted, PP F&F (SOLD)
3pdt Electronics Gristle Box (Gristleizer) - £75 posted, PP F&F (SOLD)
Hungry Robot Wardenclyffe - £140 posted, PP F&F (SOLD)
Seeker Electric Effects - Op Amp Big Muff - £100 Posted, PP F&F (SOLD)
Audio Kitchen The Big Trees - £645 Posted, PP F&F (SOLD)
Asheville Music Tools ADG-1 - £290 Posted, PP F&F (SOLD)
Zvex Box of Rock - £125 Posted, PP F&F (SOLD)
  • DoveholesDoveholes Frets: 137
    Moho added.
    Some bits sold.
    Bump.
    Analogman Memory Man added.
    More pedals added. I also have a Seeker Electric Op Amp Big Muff that I’ll be listing soon.
    H90 and ADG-1 added.
  • rich75rich75 Frets: 36
    PM sent re H90  :)
    H90 sold, Sun Bender photos added, Seeker Muff and Frost Giant Rat added.
    Sun Bender sold, Euna added.
    Bump.
    edited March 11
    The decals arrived from Seeker Electric today so those have now been added. I'm also selling a Matamp 4x12 and Orange Pedal Baby here.
    Cogmeister added.
  • Aaaargh! I was looking out for a Cogmeister but I've just bought a couple of other things instead.
  • CastroCastro Frets: 512
    Fabulous pedal, worth every penny and more. Mine is superglued to my board.
  • ChrisCox1994ChrisCox1994 Frets: 370
    oh sh*t i really want a cogmeister, any trades?
    https://www.gbmusic.co.uk/
    PA Hire and Event Management
    It often goes that way!
    100%. This is the second one I've owned and I'm sure it won't be the last.
    Sadly not - I'm raising funds for a new amp.
    Bump.
    Bump
    Slight price drop.
    New pedals added.
