I'm considering buying a 6 string Ibanez bass which I tried out last year. It's an EHB1506ms multiscale headless bass tuned B to C. I only picked it up to try it in the shop as my friend was buying a guitar and it was already on a stand next to an amp with a cable plugged in so I thought I'd kill some time!
I found it relatively easy to play, but did get a little lost briefly due to the slanted frets and extra strings. However, it didn't feel like it was something I couldn't overcome with a few hours of practice. It sounded good, had flexible electronics and was very comfortable and lightweight to play.
I did have a Fender Custom Shop Bass VI for a while, which although was fun and sounded good, it felt like more of a guitar design adapted for lower strings than a dedicated bass instrument with extended range. The strings were too close together for the right hand to play comfortably.
I use a 5 string bass for one of the bands I play in anyway, so used to a low B. There are some recordings I do which benefit from the brighter sound of playing thinner bass strings lower down the neck (a sort of baritone guitar sound) which I can't get now the Bass VI is gone. I could also benefit from a lighter bass than my 5 string Stingray for when my back starts to ache towards the end of a gig.
What are people's experiences with 6 string basses tuned B to C?
Ultimately I just didn't use the C often enough or high enough to make it worth the extra weight to carry around.
I believe the lightest 6 string on the market is now the Sandberg Superlight TM6 - it's a custom order item. Oteil Burbridge had the first 6 and seems to love it. I think they are only about 9lb which is amazing for a 6.
The Fender Bass iv isn't really a bass. It's original job was to duplicate the regular bass, but played with a pick to get some attack in the note that early precisions with flats and limited amps just couldn't do.
Ultimately - are you going to use the C string enough? That what it comes down to really.
Cons - heavy, massive wide necks, usually look silly, not a P bass
I'd consider a very narrow spaced 6 if there were such a thing.
- Book of Instruments, chapter one, verse four.
Cons: 6 strings
I'm also very surprised at the claims of an 8lb six string but stranger things have happened.
I wouldn't underestimate the "looks silly" thing. People will judge you for having a six string headless bass, particularly if you're playing "normal" rock/indie/covers and not jazz fusion. Now, you might not give a fuck and that would be a healthy attitude but people (soundmen, punters, producers, new band mates at auditions) will absolutely make a thing of it so you should be prepared. That's a story state of affairs but it's also a reality.
I tried a good 6 string for a couple of days, but found the neck width a bit of a struggle.
I find 4 strings a bit restrictive, but they were good enough for Jaco, so who cares what I think.
3 strings were good enough for Bottesini! *
* Although, TBF, the 4th string was added to the double bass because of him.
Nil Satis Nisi Optimum
Slightly silly really as my last band was a big band and when playing in all flat keys because of the transposing instruments made a 5 string really useful.
I'm not one for being bothered about looks in the slightest but the Bongo 6 did look a bit silly on me. I'm 5ft9in and although my history as a prop forward is obvious (ahem) it did look a bit silly on me.
I agree that it's often not just about the range of the instrument, it's about having more choices for fingering.
I've had some very expensive 5 strings in the past but currently only have a cheap Ibby 5 string. But one day I'd like to find a Stingray Special that is light enough for me. I love the Stingray 5 neck shape and the 17.5mm bridge string spacing.
They have gone mad on their pricing these days though.
If you are soloing a lot, or playing modern jazz that uses a lot more range then go for it! If you are buying used you hopefully won't lose any money if you don't like it.
Disclaimer - I owned a 5-string for about three years. In my case I find 6s and most 5s more or less unplayable due to the width of the fingerboard and the string spacing - mine was unusual in that it was quite narrow - but I have small hands, so my bass style is based more on hand movement than reaches anyway.
For me, the moves that are necessary to get around the fingerboard on a four string bass guitar make the music more enjoyable to play.
