I want a better Strat switch
thermionicthermionic Frets: 10019
The switch in my MIM Classic Lacquer Strat is lacking a positive, feel - it feels “soft” with no real click between the positions. I notice it has no spring like the quality switches I expected to see in there:
https://i.imgur.com/VFEf1u0.jpg
https://i.imgur.com/mw819Dp.jpg
So then - Oak Grigsby or CRL… do both have the classic spring action? Any preference of the two?
  • ICBMICBM Frets: 74494
    CRL. The action is much nicer and they're more reliable.
  • swillerswiller Frets: 1792
    10 way if you are changing it
    Dont worry, be silly.
  • thermionicthermionic Frets: 10019
    CRL ordered - thanks.
  • prowlaprowla Frets: 5119
    A Freeway (10-way) gives you other options, like neck+bridge, all three, or a couple of series options.
    It works like a normal 5-way but also switches sideways onto a second row of five.'
  • SteveRobinsonSteveRobinson Frets: 7343
    edited February 25 tFB Trader
    It is an Oak Grigsby which is standard Fender. As @ICBM says a CRL will be a big improvement.
    Ah, I can see the pics now - yes, that's an Oak Grigsby.
    According to something I read recently, they're owned by CRL now, but they're keeping making both designs.
  • tone1tone1 Frets: 5320
    Very timely thread….CRL it is then. Any suggestions of where to buy to avoid fakes?
    I just googled to see what the difference was and I found this thread:
    https://www.thefretboard.co.uk/discussion/44719/crl-or-oak-grigsby
    Same conclusions there, but the prices have gone up about 50% in 9 years!
    edited February 25
    I ordered one from Northwest Guitars, mainly because I needed a small pot of touch-up lacquer as well. Plenty of other places have them - Six String Supplies, Gear4Music, Strings Direct... although they are £30 in some places!
  • robertyroberty Frets: 10932
    CRL are pricey but they are noticeably better to use
  • nero1701nero1701 Frets: 1658
    edited February 25
    I got caught out on ebay bout a year ago.
    Oak Grigsby style switch...
    So..not an oak grigsby, less than a year in and about 4-5 gigs and its starting to miss!
  • PALPAL Frets: 601
    As already mentioned CRL.
  • FelineGuitarsFelineGuitars Frets: 11978
    edited February 26 tFB Trader
    I will only stock and supply a proper CRL switch because anything else isn’t worth it for a standard switch. Especially when it costs the same to install so for a couple of quid more you might as well have the one that feels good and will last longer
    I generally buy either from Axecaster or Six String Supplies, depending what else I might be buying/ stock availability at the time.
