Who's made the leap from HX Stomp to FM3?
LewyLewy Frets: 4459
edited March 5 in Digital & Modelling
...and what was your experience? Interested in views of learning curve, sound quality, amount of stuff you can do at once etc. My use-case is almost entirely studio based through monitors or phones, and using it as audio interface as well as tone generator.
Thanks!
  • fretmeisterfretmeister Frets: 25278
    Is the FM9 passive cooled?
    I know their racks are fan cooled (which is why I refuse to have one - the noise does my head in) - but I don't know about the FM9.
  • LewyLewy Frets: 4459
    edited March 5
    Woah...I meant FM3...need to change title!!
    Actually I'd be the same - wouldn't want a fan going
  • mrleon83mrleon83 Frets: 215
    Yup I did. Learning curve I didn’t find too bad, the deeper you go, the more it can do but out of the box it’s a definite step up quality wise (sound and build)
    My chain is comp -> distortion -amp -> cab ->reverb -> delay -> eq and it has no issues at all. I have more complex patches for recording.
    theres hopefully and update to the firmware soon which is looking like a game changer (check out the fractal forum if you’re interested)
    it’s a fair bit bigger than the stomp, just to be aware in case you’ll be desk mounting  it :-)
  • RolandRoland Frets: 9001
    The fan in my AxeFX III doesn’t worry me. It’s barely audible. Much quieter than my powered speaker, or my tinnitus for that matter.
    Super helpful, thanks. Is there a fan and if so what’s the noise like?
  • mrkbmrkb Frets: 7257
    edited March 5
    The fan spins for 3 seconds at start up and is never heard again on my FM9. Its temperature controlled, so never seems to spin up in the UK.
    Karma......
    Ebay mark7777_1
  • nero1701nero1701 Frets: 1646
    Fm3 owner here. Only fans on startup.
  • TeleMasterTeleMaster Frets: 10541
    How much do you charge?
    For you, Free xx
    I've just seen the FM3 Turbo is £1200?
    Blimey. I thought that was about where the FM9 was, and that the 3 was plenty cheaper.
    I bought a used Fm3 std. £800 if memory serves.
    I have no need for any more power.
  • BeexterBeexter Frets: 636
    I've got both an FM3 and an HX Stomp. I'd echo what has already been said. The fan on the FM3 only spins on start up- I've never heard it kick in any other time.
    The Fractal interface is not as intuitive as Line6 but the more you use it, the easier it gets.
    The Fractal offers a FAR greater depth of tweakability IF you want it but you don't have to deep dive to get great sounds. I'd highly recommend the Cooper Carter masterclass - it's not cheap but I found it to be a really worthwhile investment for learning how to get the most from the FM3.
    Based on my personal experience, the FM3 is a more capable unit and I do think it sounds better. I like the fact that it's powered via a mains IEC cable rather than an adapter too. None of this should detract from the capability of the HX Stomp though - it's still a very, very good unit and much more compact but if I had to pick one at gunpoint, the FM3 would get the nod.
    Thanks for the responses, all. Very helpful!
  • pvdmacpvdmac Frets: 16
    I have both HX Stomp & FM3.
    I bought HX Stomp first…it’s a fantastic unit….but….for me the FM3 is of superior quality.
    starting with the build…when placed side by side…the HX Stomp looks like a toy….as the FM3 is build like a tank…I think the reverbs etc sound fuller/bigger….to my ears anyway…again…not taking anything away from the HX Stomp..as I said it’s a fantastic unit…but I would take the FM3 over the HX Stomp.
  • AndyJPAndyJP Frets: 221
    I've used both Helix LT and now have an FM3. I had the Helix on loan for a couple of months.
    My 2p is that they are both really good.   Think it's easier to get a good sound from the FM3, with less tweaking.   That could be because the presets in Helix land are total mince   The Fm3 presets are a really good starting point.
    The variety in fractal land is just incredible tho.    Your imagination is the limit.
