https://edmorgan.info
I've also run it through an Ampeg SVT Classic 4x10" at the practice studio, and it sounded absolutely huge - as loud (admittedly only when overdriven) as the 450W SVT-III hybrid/solid-state amp I normally use there. Unfortunately a cab that size and weight is impractical for me now.
For guitar players, it’s probably fair to say they got slightly worse with each revision, but that’s because Fender were trying (successfully) to improve them as bass amps. When I was thinking of buying another one I actually wanted a silverface not a blackface for that reason, as well as because I became convinced it was viable with a band after watching Paul McCartney using one and competing for volume with two slightly overdriven Twins on a rooftop
Luckily it was the crappy old speaker I hadn't removed yet, but it could have been embarrassing and expensive.
I'd wager that's not the first time a blonde Bassman has experienced the Stray Cat Strut.......
Luckily it’s fairly easy to wash the grill cloth.
After I got it up here, I turned the volume knob to around 5, hit the opening licks to Little Wing and felt my internal organs and windows vibrate and shift position
