FS: Marshall Silver Jubilee Studio 2525C - £475
NCoNCo Frets: 167
edited April 20 in Amps £
Time to move away from valve amps, I find it too much hassle, but this is one for those of you who don't share the sentiment.
Bought here on the forums:
https://www.thefretboard.co.uk/discussion/comment/3271420/#Comment_3271420
It was sold to another member, then myself.
The amp is in excellent condition, with 1 or 2 minor marks. Sent for servicing with Andrew Horseman, who is a lovely person. I thought I had an issue with the tubes but everything is top-notch, can send the full report to anyone interested.
All valves have at least 80% in them, here is the report:
- Valves tested, all okay, output valves good match.
- All pots and switches cleaned.
- Valve sockets cleaned.
- Rocker switch disassembled and neon re-soldered – switch indicator light repaired.
- Soak tested under load for 1 hour.
- Reassembled & final audio test.
Footswitch included.
£550  £500 £475 collected from SE London, happy to meet somewhere.
Will only trade for strat necks with rosewood board.
