…:but I don’t think it’s for me.
My normal setup is a Kustom coupe 6L6 amp on the clean channel with limited pedal usage( a drive a fuzz and a digital delay).
Never gave digital /modeling a thougyy he until I tried a guitar out at my local shop and the guy let me use his floor modeller through an FRFR monitor. I was impressed at the fullness of the sounds plus the ability to add fx, in fact I didn’t even focus on the guitar I was demoing.
To dip my toes in I picked up a used Headrush MX5, it’s a bit meh.
Through headphones it’s very lacklustre and the drives sound fizzy.
Through the power amp of my coupe it doesn’t sound as good as my amp. The effects are good but not enough to make me want to keep it.
Would a pair of quality headphones or a FRFR speaker improve things or is the MX5 just not that great?
Modellers are best if you’re trying to achieve mic’d guitar tones for recording or sending straight to FOH, otherwise it’s a compromise.
What modeller did the bod in the shop have?
It’s enough to to go through all the modellers reviews and then realise you have all these other parameters to factor in as well.
It just wasn’t “wow” enough to overcome the issues, and so I find I’m much happier with a combo amp and a Boss IR-2 for headphone use.
I end up creating a set of patches for the Shures, monitors, and my 2x12 with Celestion f12 x200s as they all have different EQ curves.
Out of the cab, monitors / phones, the Shures are my favourite to be honest as they're totally consistent whereas sound from either of the cabs or monitors depends where my ears are in relation to them.
got the POD go, night and day difference.
The Pod Go looks really good though.
