So, Pythagoras didn’t like jazz. And he didn’t know anything about instruments and music from around the world. So he overextended his thesis.
Happens all the time.
And I really like your "everything is always out of tune, you just need to deal with it." - that exact process has been used for centuries by composers using various key / tuning relationships and capitalising on the harmonic and melodic opportunities they afford, to make the most of the compromises that must be made in pitches and intervals. Awesome stuff.
I think quarter comma meantone is the best of all the tunings, so long as you stay in key. It's gorgeous. Needs a bit of judgement to get the first four fifths precisely the same amount of out-of-tune-ness, but after that every one of the major 3rds is just. It's awesome.
Most digital pianos have a setting for just intonation if you select it from the arcane menus, definitely worth a little play with it to see the difference in sound.
If you have a piece in one key, there's no harm in recording it in just intonation if you feel like it.
Sometimes I detune my G string to better suit certain pieces
I have a guitar with something a bit like just intonation.
It's basically an optimised compromise to sound good with as many keys, as many chords as possible.
Frankly I think it is amazing, and I hardly touched my other guitars for a couple of years. I'd happily have it on all my guitars.
https://truetemperament.com/fretboards/
I usually tune the top E, and then use the tuner to get the others about right, which saves time, then tune all strings directly to top E (If you tune each string to the next, you get cumulative errors):
First I tune B 5th fret to the E, check E 7th fret to open B
G open to 3rd fret, the 9th fret on G is often way off E on some guitars
D 2nd fret to E
A open string with open E, listen for the beats around the perfect interval
bottom E open and 12th fret harmonic to top E
Then check again because guitars are made of wood, and change shape when you tighten up bits of wire tied to each end.
I trust the G less than the others, especially on a wound string on an acoustic
