Then I had an external two-button switch for enabling individual blocks on the Stomp (one was a volume block, one was an octaver).
The delays were in each of the loops (with a TRS breakout cable), so I could switch them in and out with the loop blocks (with trails).
I then had three snapshots on the main footswitches on the Stomp - one for rhythm, one for rhythm (plus one of the delays), and one for lead (plus the other delay). I only ever used one preset, because I could get everything I needed out of it - for cleans, I just rolled off the volume on the guitar.
That board also had a Powerstage 170 on it, so it was an all-in-one solution.
I want to use it for specific one-off sorts of tones where I might need to downtune to help the singers for 1 track, or add an octave for a specific part, or chuck some chorus or delay on for a Police song, etc etc.
I reckon a handful of song-specific patches in snapshot mode would be a good bet, and maybe a 2-button aux to make patching up/down easy. Will have a play with it but I like the idea of snapshots meaning I might not even need loads of patches
dead simple to use as it’s already pre programmed for the Stomp
i use the Stomp for modulations, reverb and delay, 12 String effect and fuzz. I have my drives in the Stomps effects loop and use it 4 cable method into my Simplifier MKii
https://youtu.be/PHGZYLPm6is?si=pP71iXUtCfJH3rhu
It may be because I'm a dinosaur
4CM with the Ironheart and using the Hotone Control as extra footswitches via midi. I'm mainly using it as a stomp box at the moment with the footswitches turning on/off individual 'pedals' with in the Stomp, with one as a 'clear all' Snapshot to turn off all the FX (apart from the FX loop to the Ironheart..)
I've used the Stomp live with a Morningstar MC8 before controlling snapshots when I had very specific sounds for specific songs, but I'm going for a much simpler approach now using a few sounds to cover more things. I've also used a simple two button footswitch to add more footswitches.
I think that is what the Stomp is lacking to be honest, just a few more footswitches, even expanded with midi or an aux switch you are limited to six, but there are eight blocks... It does mean you have to get creative with snapshots/presets/switches via midi to access everything!
First step would be replacing the CE2W and pitch up/down (HXOne, formerly Ricochet) that I'm currently using, then work out what other effects I need for extra material - delay, trem, maybe compression
Will have a play with it tonight
And @Rkphilpot you're right - the white one is definitely the best
