That said, look at where the master is! If that's how you can record at that volume, I'm prepared to believe the room sound is truly epic.
"Yeah, the clean is a little dark - I suppose I should've hit the bright switch for that. It does get a fair bit brighter at proper volumes."
Yes, sounds fine (not that I am any judge!) but tell you what! Why don't all you peeps that post clips buy a cheap ass Maplin sound level meter? The C weighted one mod N33GJ.
Pop it about 1.5mtrs from kit and tell us what SPL you are doing?
FYI. I cranked my Tannoy 5As a bit to get 90dBC at the midpoint about 1mtr from each.
Now listening to BBC's Jazzline coming in at around 75dBC.
JUSAFORT!
Dave.
Tsk.
This...
http://www.amazon.co.uk/Silverline-633937-Sound-Level-Meter/dp/B0015NSTLI
Is about 1/2 the price of the Maplin (11quid when I bough mine!)
You do want a C weighting for music.
Dave.
Some funky brighter cleans.
... Had never heard it before. Hmph.
I've just had a crack at those settings, bloody loud in the house! I did get more distortion and more clarity than your clip in the crunch channel, but I struggle to record at home to get a sound that's remotely similar to what's in the room (argh!) so maybe that's it?
What speakers are you using and what's the setting on the effects mix? I found that can alter the tone a bit, I tend to run mine at 12noon.
A tip if you want more brightness in your recordings - dial your presence and your treble in higher than you think you need. Mic position... the more aimed at the centre of the speaker, the sharper and brighter it will be. The more aimed at the edge, the darker and cloudier it will be. There is a gradation between the two, so sweep the microphone between these two zones until you like what you hear.
