New old pedal day: Boss GT100
Got a good deal on a mint one of these. I am going to cut down on individual pedals. I will bypass the amp sims and use the effects on this for live use. I need some BPM specific delays, and this will do. The expression pedal is a bonus.
I'll probably add a RAT or a fuzz pedal before it, and a Walrus Audio Slo after it.
The Eventide Timefactor will go, and I may replace it with a delay that can't be found on the GT100, like an echoplex Jim Dunlop or an EHX Hazarai MM.
I have spent a small fortune on individual pedals for a fairly bog standard board, so enough I say!
  • Secret_SamSecret_Sam Frets: 289
    What did the GT 100 cost if you don't mind saying?  They are starting to appear down our way now that the GX100 is out.
  • Creed_ClicksCreed_Clicks Frets: 1409
    185 pounds / €220 in my case...
    Thanks. That's about the same as here.
    Are you enjoying it so far?
  • thecolourboxthecolourbox Frets: 9927
    The Multi Overtone MO2 model is incredible
    soundcloud.com/thecolourbox-1
    Not had a chance to really dig into yet. Need to print the manual first!
