Pedalboard slightly bigger than a Nano+
ryanverbenaryanverbena Frets: 437
I suspect this is a problem most have faced - you need just enough space to fit one more pedal on your board, without having to go full upgrade. It's annoying!
I've recently picked up a trio plus which has been fantastic for practice at home, but it's really thrown off my pedal board layout (used to use a ditto, which was maybe 1/3 the size). I once used a Classic Jr, but don't want to go back to something so deep. Don't really mind so much if the top row was just deep enough to accommodate a couple of pedals horizontally, but ideally after something slightly wider than the Nano+, but not as long as the Nano Max. Any brand is fine. Wood is fine too, this one is for home use.
If only the Canvas tuner didn't have a bloody side mounted power socket - (why bother having top mounted input jacks?)
Any Ideas? I had a quick browse online, there was just so much to sort through I thought it would be easier to ask here. As it stands, my belle epoch is currently without a place.
