http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
If the wiring has push connectors, the simplest way to test if it’s the wiring or the speaker is swap the connections round. If the V30 remains dead, then it is.
Some speakers - particularly Eminence, which have the connections crimped not soldered - can develop a bad connection between the terminals and the cone braid, but Celestions are soldered so it’s less likely. If the speaker is disconnected, metering directly across the cone braids will tell you if this is the problem.
Yes, if they're in parallel.
If it is dead, sometimes speakers just do that even if there doesn't appear to be any real reason it's blown - it will usually be caused by a manufacturing fault in the voice coil. I've come across a couple of Celestions like that - both UK-made, not Chinese ones. When dismantled to find out why, there was a cold solder joint where the cone braid joins the voice coil - unfortunately unrepairable without destroying the cone.
